Greetings Posted March 13, 2014 Report Share Posted March 13, 2014 so piston chamber pointing downward a little? I drew you a picture a few posts back, it's in a link. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted March 13, 2014 Author Report Share Posted March 13, 2014 Cheers Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted March 13, 2014 Author Report Share Posted March 13, 2014 Had a second attempt... fail. When i first cracked open the salve bleeds there was gas in there, the fluid fizzed out. The bleed went well at first, pistons came out about 5-6mm ish, wound the tpa in and they came out about 6-7mm each. But after a few mins of lever squeezing the pistons were coming out less and less, now only about 4-5mm with the tpa wound all the way in. Can't see a leak but the slaves were covered in wd so it would have been hard to spot. Is a leak the most likley cause or could there still be gas/air in there? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted March 13, 2014 Report Share Posted March 13, 2014 It'll be full of air. Quote Link to comment Share on other sites More sharing options...
Blake Posted March 13, 2014 Report Share Posted March 13, 2014 You seem to be trying some more complicated methods and I'm not sure why just use a syringe with normal temperature wd Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted March 14, 2014 Author Report Share Posted March 14, 2014 (edited) I warmed the wd to get the gass out will get a syringe... or 10 cans of wd and bath bleed the b@$t@rd$ How can I be getting air in there? I'm a general nob, but I'm fairly competant mechanically, and I followed all the advice, exept the syringe bit but I don't have one to hand. Edited March 14, 2014 by *gentlydoesit Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted March 14, 2014 Author Report Share Posted March 14, 2014 Suck-sess Bled now, but with a sticky piston . Did it like you would a car in the end, pulling the lever and opening and closing the bleeds on the slaves (sucked the wd donwn the line first) with a reservoir attatched to the lever bleed. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted March 20, 2014 Author Report Share Posted March 20, 2014 Bled the front brake today, it feels like a cable v. Very light and lightning fast movment. Awsome! Quote Link to comment Share on other sites More sharing options...
