HippY Posted February 28, 2014 Report Share Posted February 28, 2014 Hey guys I need your help I have a bolt in my hub, that is stuck. The funny parts: the disc can move freely under it, so the bolt is actually stuck in the thread Tried to make a flat head row with a saw, did not work, did not have the proper screwdriver tried everything that I had Tried to untie it with a small flathead screwdriver+hammer any help? I ran out of ideas. Quote Link to comment Share on other sites More sharing options...
bing Posted February 28, 2014 Report Share Posted February 28, 2014 Drill the head of it with a 10mm drill, then gently warm the disk flange up with a blowtorch whilst trying to get the bolt stub out with pliers Quote Link to comment Share on other sites More sharing options...
trialsbikingnunn Posted February 28, 2014 Report Share Posted February 28, 2014 is there any part of the bolt sticking out from the hub? if so then use some mole grips to get it out Quote Link to comment Share on other sites More sharing options...
Mark W Posted February 28, 2014 Report Share Posted February 28, 2014 If the wheel's not actually in your bike, you can try something along these lines depending on how haggard the bolt head is now: Quote Link to comment Share on other sites More sharing options...
HippY Posted February 28, 2014 Author Report Share Posted February 28, 2014 sorry, from the disc hole actually, not from the hub axle, I should wrote that Quote Link to comment Share on other sites More sharing options...
williams Posted February 28, 2014 Report Share Posted February 28, 2014 I'm a bit lost now... Is it a bolt that is holding the disc rotor to the hub, or the axle bolt? Quote Link to comment Share on other sites More sharing options...
HippY Posted February 28, 2014 Author Report Share Posted February 28, 2014 the bolt that holds the rotor to the hub Quote Link to comment Share on other sites More sharing options...
Blake Posted February 28, 2014 Report Share Posted February 28, 2014 pic Quote Link to comment Share on other sites More sharing options...
HippY Posted February 28, 2014 Author Report Share Posted February 28, 2014 the disc is loose BTW Quote Link to comment Share on other sites More sharing options...
Blake Posted February 28, 2014 Report Share Posted February 28, 2014 Get a bigger flathead Quote Link to comment Share on other sites More sharing options...
williams Posted February 28, 2014 Report Share Posted February 28, 2014 Heat up the hub flange with a heatgun or a blow torch and then take a screw driver and just undo the bolt 1 Quote Link to comment Share on other sites More sharing options...
trialsbikingnunn Posted February 28, 2014 Report Share Posted February 28, 2014 file down the sides of the bolt head so that you have 2 parallel straight lines, get some mole grips on the flat parts and unscrew. I've done this on around 5 disc bolt before and it worked well each time 1 Quote Link to comment Share on other sites More sharing options...
dann2707 Posted February 28, 2014 Report Share Posted February 28, 2014 Mole grips without a doubt. Had it loads of times before. Comes out easy then mate!! Quote Link to comment Share on other sites More sharing options...
willackerley1 Posted February 28, 2014 Report Share Posted February 28, 2014 Cut a notch in the side on a angle then put a screwdriver in it then hit it round with a hammer. That's how I got mine out. Quote Link to comment Share on other sites More sharing options...
