Offset chainring
brisa911
Hi,
I have a flat 22t chainring on my middleburns at present but they chain line isn't straight and I need the chainring to be closer to the frame (further from the bashring)
I can't seem to find a chain ring that is anything other than flat. What's it called when it has the bolt holes offset from the cogs?
I guess my other option is to move the ring on the back. But the singlespeed kit i have on the rear only has 2 cups like this: https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcSMMxuESIKsbITvAd0FfT8GkEU7cbyfz_xhr4Kjydr2sghafzPw2w
Thanks
Edited by brisa911
It's quite a way out. Makes a clunk every now and again like it's trying to work it's way off.
The trialtech one looks good but the rear chain ring is quite tall and I like the way the gusset cups sandwich it high up.
Here's what I mean although the one I used to have was even more pronounced:
http://crev.vo.llnwd.net/o42/mtbreview/images/products/medium450/product_350806_43822.jpg
Race Face do a set of extra long inner bolts that would then allow you to play with the spacing a little without worrying about thread contact (Y)
http://www.sjscycles.co.uk/race-face-steel-inner-chainring-bolts-125mm-set-(4)-prod27175/
http://www.sjscycles.co.uk/wheels-manufacturing-chainring-spacer-each-prod17702/
