brisa911 Posted February 19, 2014 Report Share Posted February 19, 2014 Hi, Is it possible to use a hope mono mini lever upside down? Quote Link to comment Share on other sites More sharing options...
isitafox Posted February 19, 2014 Report Share Posted February 19, 2014 No Quote Link to comment Share on other sites More sharing options...
brisa911 Posted February 19, 2014 Author Report Share Posted February 19, 2014 (edited) How long will it go for? I've taken it off now but It was working great. Although i hadn't ridden it Edited February 19, 2014 by brisa911 Quote Link to comment Share on other sites More sharing options...
Blake Posted February 19, 2014 Report Share Posted February 19, 2014 30 Squeezes 2 Quote Link to comment Share on other sites More sharing options...
dezmtber Posted February 20, 2014 Report Share Posted February 20, 2014 The reservoir is designed to be the right way up. Upside down it should let air into the hose, lots of air Quote Link to comment Share on other sites More sharing options...
marko Posted February 21, 2014 Report Share Posted February 21, 2014 (edited) I had a mini master unit upside down on my bike for a bout 2 years. No problem if there is no air captured inside the reservoir. There will be no air inside if you roll the diaphragm. To make 100% sure can fill the two m3 threads with fluid before installing reservoir cap. How to - Roll a diaphragm: Edited February 21, 2014 by marko 1 Quote Link to comment Share on other sites More sharing options...
niconj Posted February 22, 2014 Report Share Posted February 22, 2014 Makes sense. Will do that on my 810 as well. Quote Link to comment Share on other sites More sharing options...
Greetings Posted February 22, 2014 Report Share Posted February 22, 2014 (edited) Exactly what I thought. The only way you'll get air in the system is when air is captured under the diaphragm. Can't figure out whether "automatic" pad adjustment will work but if it doesn't, flipping the lever and giving it a few pulls should sort it. Edited February 22, 2014 by Greetings Quote Link to comment Share on other sites More sharing options...
