Water or oil in your magura?
Dan-Walker
What fluid do you use in your magura?
30 members have voted
  1. 1. What fluid do you use in your magura?
Yarp loads of people use water. It's a bit hit and miss though whether it swells up your piston or not though.
One magura I had had endless problems with it. But the one I have now seems fine and it looks like it's been ran with water for ages.
Easy and cheap fix. Racing line alloy piston
I have used water and can say it works well .
but i would only do this if you dont have a bleed kit .water will shorten the life of your maggies also water will seep past the seals quicker than oil.
U can use washing up liquid in a powersteering unit on a car.
but this does not mean its a good idea, they use oil for a reason i would not buy a maggie that has been used with water would u
