marshole82 Posted February 5, 2014 Report Share Posted February 5, 2014 So guys and gals, Taper, ISIS, Octalink, HT2 or what? What are the benefits of each? In my day it was all taper but now if i want to upgrade my stuff i need to make sure it's all compatable! Quote Link to comment Share on other sites More sharing options...
JJ Leigh Posted February 5, 2014 Report Share Posted February 5, 2014 id say ISIS, gets the power out better than taper for me Quote Link to comment Share on other sites More sharing options...
Blake Posted February 5, 2014 Report Share Posted February 5, 2014 ISIS Most compatible in trials, stiffest and very strong 1 Quote Link to comment Share on other sites More sharing options...
chris H Posted February 5, 2014 Report Share Posted February 5, 2014 (edited) On 2/5/2014 at 4:39 PM, DrStix said: ISIS Most compatible in trials, stiffest and very strong AS30 is by far stiffer! Edited February 5, 2014 by chris H Quote Link to comment Share on other sites More sharing options...
isitafox Posted February 5, 2014 Report Share Posted February 5, 2014 On 2/5/2014 at 6:27 PM, chris H said: AS30 is by far stiffer! True but this member is just getting into trials and building up a cheap bike for learning on. My opinion is get ISIS, there's loads of 2nd hand ISIS cranks coming up for sale all the time and you'll be able to carry it across to a new frame whereas if you get taper you'll just end up buying twice. Quote Link to comment Share on other sites More sharing options...
marshole82 Posted February 5, 2014 Author Report Share Posted February 5, 2014 What's as30 then? Expensive but very strong? Always wondered about ISIS stuff, is it compatible with that octalink stuff? Quote Link to comment Share on other sites More sharing options...
Blake Posted February 5, 2014 Report Share Posted February 5, 2014 On 2/5/2014 at 6:27 PM, chris H said: AS30 is by far stiffer! Meant just to say stiff. Most trials specific cranks are isis though Quote Link to comment Share on other sites More sharing options...
chris H Posted February 5, 2014 Report Share Posted February 5, 2014 On 2/5/2014 at 6:47 PM, isitafox said: True but this member is just getting into trials and building up a cheap bike for learning on. My opinion is get ISIS, there's loads of 2nd hand ISIS cranks coming up for sale all the time and you'll be able to carry it across to a new frame whereas if you get taper you'll just end up buying twice. I wasn't reccomending it, Isis is best for most people, it was the "stiffest" comment, it's false information. I've got an as30 system and I can assure it's stiffer. Quote Link to comment Share on other sites More sharing options...
dave33 Posted February 5, 2014 Report Share Posted February 5, 2014 On 2/5/2014 at 7:33 PM, marshole82 said: What's as30 then? Expensive but very strong? Always wondered about ISIS stuff, is it compatible with that octalink stuff? As 30 is a new system crewkerz use, 30mm through axle made from alloy. Just like the shamano saint design. Isis is a splined system just like shimanos octaink but they arnt compatible with each other Quote Link to comment Share on other sites More sharing options...
dezmtber Posted February 5, 2014 Report Share Posted February 5, 2014 Ha ha, Dave Shimano use a 24mm axle size if your familar with mtb cranks square taper( used on cheap trial setups tend to snap axles and round off crank arms square fittings) octalink ( used by Shimano as there alternative to isis not trials specific) isis ( used by truvative, fsa, raceface ect.. Stronger axle less likely to snap and much less likely to round off used also by most trials crank systems) fsa omega drive 15mm axle size ( fitted to road bikes) gxp truvative 24/23mm axle ( fitted to mtbs and road bikes) Shimano, fsa and race face 24mm ( fitted to mtb and road) e thirteen and raceface 30mm ( very similar to as30 can be fitted using there bb to any frame) sram bb 30 ( only fits bb30 or pressfit 30 frames. crewkers as30 uses a 30mm axle but as with the race face and sram 30mm stated axle size i am still to find out what there axle diameter is. the sram uses a shorter axle lengnth than the as30 and raceface/e thirteen cranks Quote Link to comment Share on other sites More sharing options...
marshole82 Posted February 6, 2014 Author Report Share Posted February 6, 2014 ^^ BB guru? That clears up a lot. was looking at getting a light setup for my commuter hack and transferring the square taper to my trials build, but i may now just plump for an ISIS setup for the trials and get a lighter taper BB for the hack. Quote Link to comment Share on other sites More sharing options...
dezmtber Posted February 6, 2014 Report Share Posted February 6, 2014 Keep the square on the hack if its not snapped the bearings last much longer. if you do change over a Shimano deore or slx would be good. Unless its a road/ hybrid then go with sora. a nice set of trialtech or echo isis cranks will be good for the trial bike. Quote Link to comment Share on other sites More sharing options...
marshole82 Posted February 6, 2014 Author Report Share Posted February 6, 2014 Cheers dude. Can't find anything lighter than the raceface so I'll keep for now ) Quote Link to comment Share on other sites More sharing options...
marshole82 Posted February 6, 2014 Author Report Share Posted February 6, 2014 (edited) Can anyone recommend a good Isis setup? FSA platinum any good? Not looking to spend a tun, or even any time soon, just so I can keep an eye out. Edited February 7, 2014 by marshole82 Quote Link to comment Share on other sites More sharing options...
isitafox Posted February 6, 2014 Report Share Posted February 6, 2014 Get on tartybikes or even look out for something on here. The cheaper generic ones (onza/trialtech) will be good enough! 1 Quote Link to comment Share on other sites More sharing options...
dezmtber Posted February 6, 2014 Report Share Posted February 6, 2014 What isitafox said ^ 1 Quote Link to comment Share on other sites More sharing options...
marshole82 Posted February 7, 2014 Author Report Share Posted February 7, 2014 On 2/6/2014 at 9:30 PM, isitafox said: Get on tartybikes or even look out for something on here. The cheaper generic ones (onza/trialtech) will be good enough! On 2/6/2014 at 10:12 PM, dezmtber said: What isitafox said ^ cranks AND bb or just cranks? Quote Link to comment Share on other sites More sharing options...
dezmtber Posted February 7, 2014 Report Share Posted February 7, 2014 I just found a set of onza pro cranks in my shed of my rockman your for £10 if you like. have a look in the tf for sale threads you can easily find a 128 onza isis bb for £10 then you can change over to isis for £20 is your freewheel on the back wheel or the crank? if its on the back wheel you will need a 12t screw on cog for the wheel. Quote Link to comment Share on other sites More sharing options...
marshole82 Posted February 7, 2014 Author Report Share Posted February 7, 2014 it will be on the back so will need a sprocket for the front. if you find a buyer for your cranks then sel them as i an't afford even a tenner at the moment, but when the time comes i'll give you a shout. what length crank are they? being 6'4" on a Zebdi frame what length would you suggest? Quote Link to comment Share on other sites More sharing options...
isitafox Posted February 7, 2014 Report Share Posted February 7, 2014 Generally although not set in stone it's 165mm for 20",170mm for 24" and 175mm for 26". Quote Link to comment Share on other sites More sharing options...
