19" rim
0zzy
cheers I know it looks like a wanted but perhaps I should have written it better. I want to buy brand new and wanted to see peoples reviews off previous rims. ive been looking at echo rims as I always heard they were strong, but the main deciding factor for me is the grind, I want the best grind possible, really hate grinding it every couple of weeks.
Okay is the echo sl just a light version of the echo rim that has the good grinds or is it different? The echo sl seems a very good rim pretty light and good for grinds if it is the same material...
it's the same rim just got more holes, goes on a different production line
I don't like Echo's because of the weight and the width. I've been using a Neon light at the rear for almost a year now and it's going perfect. Even though it's single walled I personally think it's much more stronger than a Echo. For example when I run a TR, it was very common to break the wall that goes in contact with the spoke nipple, it was also cracked in the same spot all across the rim.
I'm not really sure on the grinding hold, anyway this is the one: http://www.trial-bikes.com/llanta-trasera-neon-47mm-p-536394.html don't really love the look of it, but it's something I can get over.
even though he's specified it's ability to hold a grind is the most important factor.
i'll give another vote for the echo rim, holds grinds brilliantly, it'll only fail when you've run out of sidewall material to grind, which would cause any rim to fail.
