isitafox Posted February 15, 2014 Report Share Posted February 15, 2014 Run the brake cable in the gear route? Quote Link to comment Share on other sites More sharing options...
Pete.M Posted February 15, 2014 Report Share Posted February 15, 2014 you can run vee's but need a long unbroken outer to the arms! Ha, I actually did this and completely forgot about it. Silly me. Quote Link to comment Share on other sites More sharing options...
marshole82 Posted February 16, 2014 Author Report Share Posted February 16, 2014 Lol my last comment was meant sincerely BTW Yeah I'm gonna have to either use the gear routing or get clips/zip ties. Not the cleanest of looks eh! Quote Link to comment Share on other sites More sharing options...
marshole82 Posted February 17, 2014 Author Report Share Posted February 17, 2014 Oh yeah well chuffed Trial fitted to the kona Quote Link to comment Share on other sites More sharing options...
marshole82 Posted February 18, 2014 Author Report Share Posted February 18, 2014 Well its laced! And wonky is flip lol Any tips on truing withough a proper station? Quote Link to comment Share on other sites More sharing options...
HippY Posted February 18, 2014 Report Share Posted February 18, 2014 put it into a fork, and personally I use a magura pad, but you can use anything, and using something as a reference point true the wheel. not the best solution, but it works! Quote Link to comment Share on other sites More sharing options...
marshole82 Posted February 19, 2014 Author Report Share Posted February 19, 2014 Yeah I thought about that. I may have to back off the nipples a bit and start again. It was late last night and I was getting impatient Quote Link to comment Share on other sites More sharing options...
isitafox Posted February 19, 2014 Report Share Posted February 19, 2014 Elastic band a pencil to the fork leg and use that. 1 Quote Link to comment Share on other sites More sharing options...
marshole82 Posted February 19, 2014 Author Report Share Posted February 19, 2014 Might use the missus bike, its the only standard dropout vee fork I've got! Quote Link to comment Share on other sites More sharing options...
marshole82 Posted February 20, 2014 Author Report Share Posted February 20, 2014 put it into a fork, and personally I use a magura pad, but you can use anything, and using something as a reference point true the wheel. not the best solution, but it works! Elastic band a pencil to the fork leg and use that. Used the missus GT! Only problem was rim width so found what I though was the middle, I.e. both brake arms at the same angle and went from there. Its about a mm out to the non disc side and it eggs in one place. I'm happy for now and will true it once I have forks and a brake to set up. Really chuffed with my first wheel build. Quote Link to comment Share on other sites More sharing options...
dann2707 Posted February 21, 2014 Report Share Posted February 21, 2014 I saw flipp use a cable tie of either side of the wheel attached to the fork then cut off. Seemed to work really well. Quote Link to comment Share on other sites More sharing options...
marshole82 Posted February 21, 2014 Author Report Share Posted February 21, 2014 I saw flipp use a cable tie of either side of the wheel attached to the fork then cut off. Seemed to work really well. that, sir, is not a bad idea. stored for future ref on the lookout for a matching rear hub now, the list of bits i need is really long though! Quote Link to comment Share on other sites More sharing options...
marshole82 Posted February 23, 2014 Author Report Share Posted February 23, 2014 (edited) Headset, bottom bracket and cranks donated to me by a good friend with a huge box of unused bike parts! Legend. The list is slowly coming down!Vee caliper Pads CablesForks TyresPedalsSingle Speed KitChain Grips Top capCaliper bolts Crank boltsHeadset bearings Seatpost Chainring Edited March 22, 2014 by marshole82 1 Quote Link to comment Share on other sites More sharing options...
marshole82 Posted February 24, 2014 Author Report Share Posted February 24, 2014 Extended list! Always the little things... Quote Link to comment Share on other sites More sharing options...
marshole82 Posted March 3, 2014 Author Report Share Posted March 3, 2014 Princely sum of £19 delivered. New chain, good condition gusset single conversion kit from eBay. Yeah boi lol Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted March 4, 2014 Report Share Posted March 4, 2014 Half link chains are the worse chains you can use. They stretch really easy and are prone to snapping. Quote Link to comment Share on other sites More sharing options...
marshole82 Posted March 4, 2014 Author Report Share Posted March 4, 2014 doesn't look like i can use it with my sprockets anyways. bah. i really wanted a green one. any chains you can recomend that will work on standard MTB sprockets, good enough for trials, and in various colours? Quote Link to comment Share on other sites More sharing options...
Blake Posted March 4, 2014 Report Share Posted March 4, 2014 Those sprockets should work, I assumed you where attempting to use them on a geared setup. Swap that chain out though Quote Link to comment Share on other sites More sharing options...
marshole82 Posted March 4, 2014 Author Report Share Posted March 4, 2014 yeah the sprocket is fine but i was under the misaprehension that a single speed bmx chain would be ok. after all, how much difference can there really be between 1/8" and 3/32"? apparently enough haha knew KMC may be on it's way if i can first check about chain length - i dont want to have to spend more on a tensioner and a mech dropout when this is supposed to be on the cheap. Quote Link to comment Share on other sites More sharing options...
marshole82 Posted March 5, 2014 Author Report Share Posted March 5, 2014 Ah saved by a mate! A BMXer has bought me a 610 in exchange for the green thing! Whoop! Quote Link to comment Share on other sites More sharing options...
marshole82 Posted March 6, 2014 Author Report Share Posted March 6, 2014 aaaaan i've gotten myself some vbrakes. needless to say my old sh*tty avids wont be too strong so have got some 'retro' (as the ad said lol) LX. before they moved to the parallel stuff - £13. ace Quote Link to comment Share on other sites More sharing options...
marshole82 Posted March 13, 2014 Author Report Share Posted March 13, 2014 And a quick mock up as still need a few key parts! 1 Quote Link to comment Share on other sites More sharing options...
marshole82 Posted March 17, 2014 Author Report Share Posted March 17, 2014 alot of people are going to tell me that this was stupid, but for £10 posted i've got some Scott v-mount forks. yes they are standard MTB so won't be up for big drops etc, but for a tenner, and the fact that i wont need to source a disc brake i'd be silly not to as a short term thing. i've said it before, but i can't even trackstand at the minute, so the liklihood of me doing any drops ore hopping across railings is very slim. if i get decent then i can swap my forks out for something better and stronger. it's coming together slowly, hopefully will get a ride this summer! Quote Link to comment Share on other sites More sharing options...
err Posted March 17, 2014 Report Share Posted March 17, 2014 Nothing wrong with mtb forks on your first bike! I started out on my old chameleon with a set of gt forks. 1 Quote Link to comment Share on other sites More sharing options...
marshole82 Posted March 17, 2014 Author Report Share Posted March 17, 2014 Nothing wrong with mtb forks on your first bike! I started out on my old chameleon with a set of gt forks. Hard to get trials specific forks with v bosses. The Scott ones I've bought should do for now. Quote Link to comment Share on other sites More sharing options...
