wez k Posted February 1, 2014 Report Share Posted February 1, 2014 Hi jumped on bike this morn and noticed cranks creaking. It happens when pedals are under load and rotating I.e. when pedaling on a flat. I not had chance to investigate yet.but how difficult is it to strip necessary components then to rebuild thanks Quote Link to comment Share on other sites More sharing options...
HippY Posted February 1, 2014 Report Share Posted February 1, 2014 Do they move, or they just making noise? Do you feel any rubbing? Very first step, pull the bolts on the cranks really tight, you must have them tight Quote Link to comment Share on other sites More sharing options...
wez k Posted February 1, 2014 Author Report Share Posted February 1, 2014 There doesn't seem to be any play just creaking under load while pedaling. don't feel any rubbing.when I get chance I will investigate further. if I need to remove cranks how do I do this. Quote Link to comment Share on other sites More sharing options...
Blake Posted February 1, 2014 Report Share Posted February 1, 2014 Buy a crank puller, tarty sell a good one or a local shop should have one. Then follow instructions online Quote Link to comment Share on other sites More sharing options...
isitafox Posted February 1, 2014 Report Share Posted February 1, 2014 You need a crank puller to remove the cranks, what frame is it? It might be worth greasing the bottom bracket as well. Quote Link to comment Share on other sites More sharing options...
wez k Posted February 1, 2014 Author Report Share Posted February 1, 2014 Don't have a crank puller is there amother method I got a car ball joint splitter the fork type. The bike is 2009 onza rip with standard components Quote Link to comment Share on other sites More sharing options...
isitafox Posted February 1, 2014 Report Share Posted February 1, 2014 You could probably force it off with a mallet but I wouldn't recommend it. Have you tried just removing the pedals and greasing the threads on them? Quote Link to comment Share on other sites More sharing options...
wez k Posted February 1, 2014 Author Report Share Posted February 1, 2014 Not had chance yet just getting advice before I attemp anything serious.I will keep you informed once I've had a play Quote Link to comment Share on other sites More sharing options...
wez k Posted February 1, 2014 Author Report Share Posted February 1, 2014 Took a look at crank. took left side off greased spindle refitted crank.tightened up.not sure how tight it should be but done it quite tight. And Bob's your uncle no more creaking. Unlike my bones.being a new trials rider at 30 something 1 Quote Link to comment Share on other sites More sharing options...
