onza rip rear wheel HELP!
wez k
Here is my problem I got a puncture in my rear wheel I released to big nuts either side if axle but wheel would not move noticed some sort of locking spacer that's wedged between nuts and frame with a bolt on then a small hook clamp which you can turn I'm not sure but I think this tightens the chain finally after a bit of force with mallet banging wheel to front of bike was able to move chain off sprocket thus removing wheel.fixed puncture now comes the head wrecking part refit wheel what is the correct procedure cause when everything is lined up tightened up a few turns of the pedals then chain goes mega tight where you can feel the bearings running what am I doing wrong this has got to be the longest ever puncture repair please help
alright. First please rephrase it so human beings can read it and understand it as well please
so after you tighten the nuts on the side of the wheel, and on no load, so when the wheel is in the air and you push the pedal with your hand, the chain tensioned nicely, but when you pedal the bike on the ground, it became super tight?
I would tighten the nuts as much as I could
spacer? is it looks like this
http://www.tartybikes.co.uk/snail_cams/monty_snail_cam_tensioners/c114p2092.html
or this
http://www.tartybikes.co.uk/product.php?product_id=12293&keywords=Inspired+Arcade+Micro+Chain+Tug
After researching they are chain tugs I put wheel back in lined it centre tighted wheel nuts so chain is tensioned then just nipped up chain tugs so clamps are not lose chain had about half inch play then while bike is still in the air I turned pedals a few times but chain went mega tight and I could feel the bearings rubbing
personally I would set the chaintugs first, so the wheels will be in position and the chaintug will be tight enough then tightening the nuts on the side
Please, write in sentences, it is really hard to understand your exact problem, if you write everything into one long sentence
Thanks for your help.I don't know if you can tell I'm a complete newbie to trials. I brought a used onza rip not sure what year but it's only got basic setup including v brakes. Suppose it's ok for a beginner at only £50 I can't grumble so any help and advice would be much appreciated. I would also like if there are any local riders in Nottingham who's willing to teach an old dog some new tricks
everyone need to start off somewhere :) I had a £60 Base trials bike, and I had the same problems as you, and I am still progressing really slowly after 2 years
I would say 2 things: keep your bike in a good condition and ride as much as I can, a few times in a week (if you can).
Whenever I took longer breaks, I lost loads of knowledge, that is the reason why I am building a new bike, so the fault of the bike will not make me on a break.
Start off with you balance. Track stand, pivots, just basically playing around with the bike in one place, with both brakes pulled, so you can get the feeling of the bike and your balance
after that I would do some pedal ups, and back wheel hops.
and after... well, watch videos about others, what lines do they ride and how, and then go for it :)
