Marino's archive 1.5 tapered head tube model
Ross McArthur
280USD for a standard frame (no CNCd dropouts)
320USD for integrated tensioner bolt cnc dropouts a la echo.
90USD for forks.
Everything's heat treated for that price.
110USD for express shipping to uk. 1-2 weeks.
All those Archive frames are off the shelf frames which are ready to be purchased if anyone's keen?
Would I be right in thinking the taper headtube version of the frame/fork uses the same downtube, fork leg diameter and crown area (obviously getting chunkier above where the legs weld on, but the actual area where the legs weld on I mean...) as the standard version? It looks like it from the photos but just thought I'd check.
By looking at my forks here & comparing, it definitely looks like a bigger part.
The welds are much further apart on the 1.5 forks, the gap on mine between the welds is only 9mm at the closest point, it's gotta be around 20mm in this pic.
post-1701-0-19045100-1389566591_thumb.jp
Edited by LEON
