*gentlydoesit Posted January 9, 2014 Report Share Posted January 9, 2014 I've taken my new wheel to my lbs to be straightened. The dish is miles out on their jig I was going to buy a 135mm axle from tarty but they don't stock them. Any ideas how they can dish the rim with a 116 axle so when I find a 135 its just a quick swap? I'll do a youtube link in a while so you can see what I mean as thets probably not very well worded Quote Link to comment Share on other sites More sharing options...
AndrewEH1 Posted January 9, 2014 Report Share Posted January 9, 2014 I've taken my new wheel to my lbs to be straightened. The dish is miles out on their jig I was going to buy a 135mm axle from tarty but they don't stock them. Any ideas how they can dish the rim with a 116 axle so when I find a 135 its just a quick swap? I'll do a youtube link in a while so you can see what I mean as thets probably not very well worded Just get your money back... If Brad wants his wheel back he should pay shipping. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted January 9, 2014 Author Report Share Posted January 9, 2014 The bike shop said a tenner to true it, can't not be worth it can it? The axle on tarty says "direct replacement" no mention of the dish being off if you swap . Anyone got a 135 tr hub that can take a measurement of the spacers? Cheers Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted January 9, 2014 Report Share Posted January 9, 2014 (edited) erm,the wheels dishing isnt related to the axle width,if an axle is mounted the correct way the rim is in the same location as before.if its out that much it isnt laced properly. sorry to say,mate only other thing i can imagine is you need other spacers for the new axle,maybe they got swapped unintentionally? Edited January 9, 2014 by FamilyBiker Quote Link to comment Share on other sites More sharing options...
bing Posted January 9, 2014 Report Share Posted January 9, 2014 It shouldn't be, the echo 116/135 hubs use the same shell, just a different length axle. If the wheel isn't in the centre of the flanges, it's not dished right. Reasons for this are unequal spoke lengths, too much tension on one side more than the other. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted January 9, 2014 Author Report Share Posted January 9, 2014 See that's what I thought :! I couldn't understand how it wasn't dished center to the spacers it has?!Vid soon Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted January 9, 2014 Author Report Share Posted January 9, 2014 http://youtu.be/RZPW-L767YA Quote Link to comment Share on other sites More sharing options...
bing Posted January 9, 2014 Report Share Posted January 9, 2014 Can't understand how brad ran the wheel like this, it must have sat to one side in the frame. Have you got the spacers on right. I don't mean to insult your intelligence but it's very easy to get then mixed up. Put it in your frame as it is with the brake cylinders on and take a photo Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted January 9, 2014 Report Share Posted January 9, 2014 (edited) in that vid i´ve only seen that it isnt trued properly. was that truing stand centered? in that case you´d have 8-10mm offset,i would say that wheel isnt laced properly. how are the spokes sitting in the nipples,seen from above the rim/nipples? are they poking out/even/uneven? edit:and what bing said. Edited January 9, 2014 by FamilyBiker Quote Link to comment Share on other sites More sharing options...
bing Posted January 9, 2014 Report Share Posted January 9, 2014 If it were a free hub, then the centre of the rim should sit above the centre of the axle. This is also true of the fixed hub, but you should be able to get in in the middle of the flanges as well, ensuring a fully central wheel. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted January 9, 2014 Author Report Share Posted January 9, 2014 (edited) The spacers can't be wrong, or at least didn't do it they don't come off because their mullerd, though not enough to be that far out. The dude at the bike shop set the jig up, I assume he's got it right, the other wheel he did was bang on *yeah some spokes pertrude the top of the nipple Edited January 9, 2014 by *gentlydoesit Quote Link to comment Share on other sites More sharing options...
isitafox Posted January 9, 2014 Report Share Posted January 9, 2014 New/correct spokes and fresh rebuild. Almost sounds like why he wouldn't sell it to one of his mates. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted January 9, 2014 Author Report Share Posted January 9, 2014 If someone (maybe at tarty ) could give me a dimention/s for the spacers I think I've got a plan New/correct spokes and fresh rebuild. Almost sounds like why he wouldn't sell it to one of his mates.I doubt that he rode the wheel like that! It'd be rubbing the brake real bad. Quote Link to comment Share on other sites More sharing options...
chris H Posted January 9, 2014 Report Share Posted January 9, 2014 Are you after an echo 135 axle? Quote Link to comment Share on other sites More sharing options...
trials hoe Posted January 9, 2014 Report Share Posted January 9, 2014 I have a 135 axle (bodged a bit) and the non-snail cam spacers if they're any use to you? Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted January 9, 2014 Author Report Share Posted January 9, 2014 Are you after an echo 135 axle?yes I have a 135 axle (bodged a bit) and the non-snail cam spacers if they're any use to you?yes, how bodged? Quote Link to comment Share on other sites More sharing options...
trials hoe Posted January 9, 2014 Report Share Posted January 9, 2014 I filed the axle to run 18-14 on a stock with vertical dropouts, bit of a fiddle to setup but I ran it on my echo ages ago and it did the job. If it covers you till tarty have em in stock, you're welcome to it Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted January 9, 2014 Author Report Share Posted January 9, 2014 I filed the axle to run 18-14 on a stock with vertical dropouts, bit of a fiddle to setup but I ran it on my echo ages ago and it did the job. If it covers you till tarty have em in stock, you're welcome to it Quote Link to comment Share on other sites More sharing options...
trials hoe Posted January 9, 2014 Report Share Posted January 9, 2014 (edited) You can see what I mean by bodged haha, no axle washers though Also other stuff in the pic I'm sure I've seen in a wanted ad, so someone somewhere wants them bits too... Edit - forgot the pic haha Edited January 9, 2014 by trials hoe Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted January 10, 2014 Author Report Share Posted January 10, 2014 You know I pm'd Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted January 10, 2014 Author Report Share Posted January 10, 2014 (edited) If it were a free hub, then the centre of the rim should sit above the centre of the axle. This is also true of the fixed hub, but you should be able to get in in the middle of the flanges as well, ensuring a fully central wheel. so if the hub were in the jig on the bearings outside edges, the rim could be dished at that? Edited January 10, 2014 by *gentlydoesit Quote Link to comment Share on other sites More sharing options...
bing Posted January 10, 2014 Report Share Posted January 10, 2014 Yes mate. It will work providing the spacers allow the wheel to sit in the middle of your frame. Can't see a reason why it shouldn't like. If I was more local to you I'd come and have a look and maybe fix it for you Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted January 10, 2014 Author Report Share Posted January 10, 2014 Always welcome down my way bud. I've got some measurements from trialshoe so it should be easy, there's a 5mm off set to the sproket side. Vid up tomorrow Quote Link to comment Share on other sites More sharing options...
bing Posted January 10, 2014 Report Share Posted January 10, 2014 What's brum like to ride? Might consider a trip down with thinkdougie if he's up for it Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted January 10, 2014 Author Report Share Posted January 10, 2014 There are some decent spots, though I'm probably not the best person to ask, being a noob Quote Link to comment Share on other sites More sharing options...
