Theo Sanders Posted December 28, 2013 Report Share Posted December 28, 2013 For the past couple of days I've been concentrating on gap-to-fronts and up-to-fronts, and today I noticed I have 3 broken spokes on the disc side of the front wheel. The broken spokes are circled in red, and one of them has also damaged the hub a bit (circled in blue). And by the way, it is the second time this happens in about a month. I have standard spokes that go on Echo Lite mod. Is that normal? If not, what's wrong and can I do something about it? And if it might be significant, I twisted the bars forward "à la" John Carthy... Thanks for the help, Theo Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 28, 2013 Report Share Posted December 28, 2013 If you're practicing front wheel moves with a disc brake there's gonna be a lot of stress on that side of the hub, I'd have thought the spokes are too tight so rather than allowing a little flex they're just snapping. Quote Link to comment Share on other sites More sharing options...
Theo Sanders Posted December 28, 2013 Author Report Share Posted December 28, 2013 ...so what exactly should I do with them? Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted December 28, 2013 Report Share Posted December 28, 2013 If you can't work it out from that more than obvious suggestion, take it to your lbs and get it checked out. 1 Quote Link to comment Share on other sites More sharing options...
Theo Sanders Posted December 28, 2013 Author Report Share Posted December 28, 2013 Should probably do it... I'm really bad at all this technical stuff anyways Quote Link to comment Share on other sites More sharing options...
Blake Posted December 28, 2013 Report Share Posted December 28, 2013 new spokes and a new wheelbuild from someone who knows what their doing Quote Link to comment Share on other sites More sharing options...
Theo Sanders Posted December 28, 2013 Author Report Share Posted December 28, 2013 You mean at tarty bikes they don't? 1 Quote Link to comment Share on other sites More sharing options...
harmertrials Posted December 28, 2013 Report Share Posted December 28, 2013 John Carthy 1 Quote Link to comment Share on other sites More sharing options...
err Posted December 28, 2013 Report Share Posted December 28, 2013 (edited) I think he means echo themselves, I'd imagine all their wheels are machine built. Echos wheels I mean Edited December 28, 2013 by err Quote Link to comment Share on other sites More sharing options...
dezmtber Posted December 28, 2013 Report Share Posted December 28, 2013 Looks like a 2x wheel build try a 3x rebuild Quote Link to comment Share on other sites More sharing options...
williams Posted December 28, 2013 Report Share Posted December 28, 2013 I've heard that when one spoke snaps, you migh weaken the others, and if many starts snapping you weaken them even more. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted December 29, 2013 Report Share Posted December 29, 2013 spokes need even tension throughout the wheel for a good wheel build, this will ensure a straight rim and even stress distribution. as said, looks like they were tightened too much causing the heads to shear. at this stage you have no idea what kind of fatigue has been seen by the remaining spokes, you may get away with dropping new ones in there, but a fresh 3x wheel build should be on the cards. disc brakes cause significant stress to spokes, but it is an odd one, had the rim been used previously? been flat spotted? and then attempted to rectify the flat spot with spoke tension? Quote Link to comment Share on other sites More sharing options...
jigga Posted December 29, 2013 Report Share Posted December 29, 2013 (edited) I had this problem on a rear Echo wheel. I had it re-built with brand new DT swiss spokes and the problem didnt go away. After more spoke breakages I had a mate in the LBS put it in the wheel truing jig. We found the rim wasnt constructed properly. one side of the rim was slightly lower than the other which meant whenver it hit the ground coming off an object or drop-off the left side spokes where momenterily under much more stress the the right as they loaded up 1st, so would snap on impact in the same place as yours. The rim the 24" Echo urban on a TR hub with Echo spokes. This was just down to crappy Echo build quality. I replace the rim and the problem was solved. Edited December 29, 2013 by jigga Quote Link to comment Share on other sites More sharing options...
Theo Sanders Posted December 29, 2013 Author Report Share Posted December 29, 2013 Thanks everyone had the rim been used previously? been flat spotted? and then attempted to rectify the flat spot with spoke tension? The bike was completely new when I got it, and as of now there don't seem to be any seen damages to it. Of course when the spores broke it went a bit crooked, but I've just taken the bike back from the shop and everything seems to be ok right now. John Carthy And sorry, my fault, of course I meant Jack... should have been thinking of something else at that moment. My appologies Quote Link to comment Share on other sites More sharing options...
