Smiley17031991 Posted December 23, 2013 Report Share Posted December 23, 2013 this question has been bugging me for awhile...but is it possible to change hydraulic levers and piston from one caliper to another such as use magura hs33 calipers on magura louise disc levers and pistons. i understand the piston roughly has to have the same pressure and movement of fluid...mainly this is so can have matching levers on my bike rather than to different sets Quote Link to comment Share on other sites More sharing options...
forteh Posted December 23, 2013 Report Share Posted December 23, 2013 Typically you hs33 and disk levers aren't interchangeable. The disk lever pushes far less fluid (smaller piston diameter) so the hs33 pads would barely move. If you're desperate to match front and rear levers with disk and hs33 you could get a 2014 hs33 and a magura mt08, they both have similar lever designs and would largely match - expensive way to do it though! Quote Link to comment Share on other sites More sharing options...
