jack iveson Posted December 19, 2013 Report Share Posted December 19, 2013 Hi, i have bought a try all k2 rear hub for my new mod and also a echo titanium spocket . When i threaded the sprocket onto the hub there was 3 or 4 threads showing on the outside . Do i have to run a spacer or anything because atm it doesnt look like the chain will go around without hitting the spokes and hub. If anyone can help me out please do Thanks jack Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 19, 2013 Report Share Posted December 19, 2013 If the chain does hit the spokes then it'd be as well to get a spacer involved. Ideally not too thick though as you don't really want to lose too much thread contact - 7 threads is the minimum you need ideally. Quote Link to comment Share on other sites More sharing options...
jack iveson Posted December 19, 2013 Author Report Share Posted December 19, 2013 A freind of mine has the same set up and said its absalutly fine but thank you Quote Link to comment Share on other sites More sharing options...
Perez Posted December 21, 2013 Report Share Posted December 21, 2013 Use steel spacer dude, very important! Quote Link to comment Share on other sites More sharing options...
