Arcade frame kit built up
monkeyseemonkeydo
Got my frame kit yesterday and after a couple of wee snags have got it together. For some reason my chainring hits the stays with the standard number of spacers so I've added another on the drive side and have ordered a 1mm Hope spacer to replace it so I have a little more thread contact. Also have Shimano rotors on the way as one of these Alligator ones has somehow spontaneously bent while off the Skye. Pants pictures ahoy!
I can confirm the other chap's experience that the Hope hoses are too fat to allow you to use the normal hose clips so I had to use zip ties. I imagine they'd work if the plastic coating round the hose was removed locally but that seems a bit overkill.
Spec is primarily Skye Mk1 with a few changes:
70mm x 25 degree Hope stem
Shimano SLX cranks
El Cheapo plastic pedals modded with pins
Eclat Gonzo seat with plastic painted black
Brown grips
Hope barends
Alligator 'wind cutter' rotors, soon to be changed for Shimano Ice Tech
Out of interest why are people going for these over the skye? I thought the skye was the top specced Frame?
Is it because people are preferring steel?
It has been said on here several times that the geo is quite different
the arcade has a longer reach, which makes the bike a lot more "static backwheel moves" friendly
another way to sees it is
if you want to ride "a la" danny mac ---> skye
if you want to ride "a la" Ali c ---> arcade
  • Like 1
Have you had much time to ride this?
Not at all yet unfortunately!
I got the Skye on a whim and because it was available but hadn't really sussed out the geometry being suited more to a small person... I still love the touches like through rear axle etc. but dislike having to run a tensioner.The other side of it is that the Arcade has fairly BMXy geometry which I like idea of as well as the shorter chainstays compared to the Skye.
If no one jumps on the Skye frame and forks I'll probably keep them for a while just to be sure I'm making the right choice but fingers crossed.
Don't start the Danny mac vs Ali thing. They're both world class but worlds apart as far as skill set goes. Danny cant touch Ali for tech but f**k me Danny goes big.
Bang on there. Danny just has the funding to get into the public eye, whereas Ali doesn't which is a real shame.
I think the simplest way to put it is they have different styles and different people will like each of them. Personaly i think they are both amazing and deserve the greatest respect for what they do not to be compared to one another and say one is better than the other
