Leak Identification, Common problem?
Milo
Guys, would appreciate it if any one could help me out with this.
I have a minor leak on my Echo front hydraulic disk brake. The leak is on both the front and rear of the brake lever in the area shown. It does not drip although the oil is there.
Im not too clever with hydraulics and new to Echo, does anyone know what would need replacing / fixing?
Thanks
post-36308-0-80167800-1386758293_thumb.j
The part you're pointing to is just the lever pivot bolt, so it can't be leaking from there exactly. But the oil could be reaching there from the bore. Echo are fairly notorious for leaking from the bore, try getting a different piston or o rings for it if it's leaking from there. X
  • Like 1
adam,did they kind of adapt the old julie low pressure system then?
Erm, sort of, I guess. The pressure is nearly as high as a normal disc brake due to the leverage ratio of the lever, though...
It doesn't work like that unfortunately or loads of people would do it.
It would do to be fair, just people don't seem to have tried it!
Do you mean just with the Echo disk levers or disk levers in general? I tried it with an Avid hydraulic disk lever and couldn't get it to work properly. It could have just been down to me not doing it properly though.
the fact aside that a lever designed for brake fluid will never work on a brake system for mineral oil,no.only old julies and the echo (aparently) have a low pressure,high volume system
edit:oh, and an old sachs disc brake that looked like a truck brake,but had plenty of power.
http://www.velomobilforum.de/forum/attachment.php?attachmentid=39977&stc=1&thumb=1&d=1359838342
Edited by FamilyBiker
