Gu le frame intergrated tensioner bolt
tdubz
That is the M6 one you keep mentioning
http://www.tartybikes.co.uk/other_frame_spares/onza_m6_integrated_tensioner_replacement_bolt/c127p12050.html
If you read the description it talks about not suitable for GU frames
However this one is
http://www.tartybikes.co.uk/other_frame_spares/stan_titanium_echo_integrated_chain_tensioner_bolt/c127p12072.html
But out of stock and doesnt give an "M" size for it so i can find one elsewhere.....
However this one is
Both likely to be m6 but just measure the current one you got. That M just means millimeters too. I think the difference between the bolts is the end the echo is juat normal as it goes into the axle not a little cap thing like the onza ones as i doubt they have odd pitches its either gonna be a standard fine or course thread.
