Removing foam grips
Dazza1414
is it literally a case of forcing liquid under the grips then?
Its easy.
Just take a screwdriver or something plastic if you dont want to scratch the bars, stick it in under the grip to about half way, pour some of it in then just move the screwdriver around the bars untill you can pull the grip off.
Its easy.
this was my original plan but I wasn't sure if it would damage the grip in the process.
if your done with them, knife, and it only scratches your bars if you do it wrong (dont cut all the way through) then just rip them off ;)
oops wrong things haha, washing up liquid, and soak them before you put them back on. that way, no soapy stuff and all you need to do is wait for the water to dry, which is quicker than soapy stuff. thats what i do :)
