Will a heatsink tensioner work with my frame
Trials-Mikey
so after receiving my jaf i have had tonnes of chain tension problems due to the frame being splayed. so i was having a think for a solution and i thought the heatsink tensioner might work. i had a look on tarty hoping to see how i should set it up, anyone had any experience with them and how well they work and a picture of it set up. Do they work on mods ?
thanks
You're overthinking this man, it's a lot easier than you're making it out to be. It should fit between your snail cams unless you have a real tight fit to put the wheel in. Unless you're forcing the frame apart to put the wheel in you'll be fine.
"How well do they work with freeweels?"
They're designed to work with freewheels.
