Zoot build thread
onzatpro09
As it says on the tin- a zoot build thread. It will be a slow process, but hopefully worth it. Anything marked '*' is something I hope to swap out.
Current spec:
2011 Zoot frame and forks*
Echo platform pedals
Trialtech cranks, 170mm
Echo sl freewheel
Trialtech bashring
Inspired arcade bars
Echo headset
Try-all BB
Trialtech stem w/ 25mm of spacers
Inspired pivotal saddle
Dual magura MT4 disk brakes, 180mm rotors
Gusset tank chain (massive!)
Onza porcipaw grips*
Front wheel:
Onza square hole single skin rim on a tensile disk hub, all black, random tube.
Rear wheel:
Onza drilled double skin rim also on a tensile disk hub, all black, continental downhill tube.
Schwalbe table top 24x2.25 front+rear
Hoping to get some inspired forks, and a fourplay frame at some point.
Edited by onzatpro09
Nice job dude, looks tidy in orange.
It does, but I think I can see myself changing it. When I first got it done I liked it most likely because it was new but it has worn off a bit. It was supposed to be matte bright orange (I know, oxymoron) but I think it is slightly too yellow. I'm thinking maybe a nicer orange, dark purple, lime green or royal blue frame with black everything else.
  • 1 month later...
Email tartys quick you ordered a tryall bb in 122 your zoot needs a 127.5 mm bb.
Will do... I don't know why I thought it was a 122. Hopefully they should read their emails before they ship it out :P
In a couple of months it's my birthday so some inspired forks may be in order too :)
