Daffy-Duck Posted November 13, 2013 Report Share Posted November 13, 2013 Whats a good chain tension?? dont know if ive got it too loose, too tight, or just right cheers Quote Link to comment Share on other sites More sharing options...
isitafox Posted November 13, 2013 Report Share Posted November 13, 2013 I tend to squeeze the chain up to the chainstay with my hand until it's about 5-10mm off 1 Quote Link to comment Share on other sites More sharing options...
Blake Posted November 13, 2013 Report Share Posted November 13, 2013 tight so it doesn't sag when looking at it, loose enough so it doesn't add more resistant when back pedalling 3 Quote Link to comment Share on other sites More sharing options...
niconj Posted November 22, 2013 Report Share Posted November 22, 2013 (edited) tight so it doesn't sag when looking at it, loose enough so it doesn't add more resistant when back pedalling I've never noticed any higher resistance (ON the bike) when back pedaling and I always tighten the chain as much as I can. Edited November 22, 2013 by niconj Quote Link to comment Share on other sites More sharing options...
Blake Posted November 22, 2013 Report Share Posted November 22, 2013 in fairness both my cogs are bent to shit Quote Link to comment Share on other sites More sharing options...
customrider-Rhys Posted November 22, 2013 Report Share Posted November 22, 2013 I've never noticed any higher resistance (ON the bike) when back pedaling and I always tighten the chain as much as I can. don't do that, you will f*ck your freewheel up in no time, caused by putting to much strain on the bearings, trust me.. my mate used to do it super tight, got told loads of times to slacken it, went through 3 freewheels in a couple months before he listened, as said you want it so it doesn't sag when looking at it, the freewheel spins freely when turned back wards and that the bottom side of the chain will touch the chain stay without much force.. so around an inch of play Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted November 23, 2013 Report Share Posted November 23, 2013 (edited) an inch is a bit much. did you ever notice the fact the chainwheel/sprocket wear unevenly over time? adjust your chain tension so the chain is tensioned right at one of those tight spots,leaving it so it can just move up and down a few mm up to a cm. ive seen cracked bearing races due to tightening the chain full on Edited November 23, 2013 by FamilyBiker Quote Link to comment Share on other sites More sharing options...
