williams Posted November 9, 2013 Report Share Posted November 9, 2013 Hey all! I've taken my bike apart now, and when I'm servicing the whole bike I want to make sure the freewheel is spot on. I've heard some guys say that leaving the freewheel in a bath with some kind of lube cleans it out, is this true? Or would it make some damage? Sorry for a bit of a stupid question, but I value my teeth's more than not looking stupid on the forum.. Quote Link to comment Share on other sites More sharing options...
Blake Posted November 10, 2013 Report Share Posted November 10, 2013 Leave it in a penetration fluid like WD or GT85 as opposed to just oil x Quote Link to comment Share on other sites More sharing options...
trials hoe Posted November 10, 2013 Report Share Posted November 10, 2013 I left my sl in a bath of r/c fuel for a bit, gave it a swill and blasted it out with wd40 then used spray Teflon lube to get everything lubed up for use. Worked a treat, sounded better after it was cleaned too. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted November 10, 2013 Report Share Posted November 10, 2013 Can you not take it apart and clean it manually? Quote Link to comment Share on other sites More sharing options...
williams Posted November 10, 2013 Author Report Share Posted November 10, 2013 Leave it in a penetration fluid like WD or GT85 as opposed to just oil x Okey so some kind of fluid that 'cleans' and then oil it up with teflon oil? x Can you not take it apart and clean it manually? Nah, tried taking apart my old freewheel and I can't really be bothered.. I left my sl in a bath of r/c fuel for a bit, gave it a swill and blasted it out with wd40 then used spray Teflon lube to get everything lubed up for use. Worked a treat, sounded better after it was cleaned too. Sounds good that! Better sound is definetely a good plus Quote Link to comment Share on other sites More sharing options...
Blake Posted November 10, 2013 Report Share Posted November 10, 2013 What freewheel is it? Quote Link to comment Share on other sites More sharing options...
williams Posted November 10, 2013 Author Report Share Posted November 10, 2013 Echo SL Quote Link to comment Share on other sites More sharing options...
Blake Posted November 10, 2013 Report Share Posted November 10, 2013 Yeah just soak it in something overnight then drop some oil in it x Quote Link to comment Share on other sites More sharing options...
williams Posted November 10, 2013 Author Report Share Posted November 10, 2013 Leave it in something that cleans then? x Quote Link to comment Share on other sites More sharing options...
Blake Posted November 10, 2013 Report Share Posted November 10, 2013 yeah WD or GT overnight. Or something else if you have anything available. x then let it dry and drop a bit of oily in there Quote Link to comment Share on other sites More sharing options...
williams Posted November 10, 2013 Author Report Share Posted November 10, 2013 (edited) Okey cheers! Yeah I have this kind of penetrating oil, should be good! x EDIT: We don't even have WD or GT in Sweden Edited November 10, 2013 by williams Quote Link to comment Share on other sites More sharing options...
trialsiain Posted November 10, 2013 Report Share Posted November 10, 2013 There's no wd40 or gt85 ? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted November 10, 2013 Report Share Posted November 10, 2013 get yourself a cheap ultrasonic cleaner. Quote Link to comment Share on other sites More sharing options...
forteh Posted November 10, 2013 Report Share Posted November 10, 2013 Soak it in petrol, then lube with a light oil Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted November 10, 2013 Report Share Posted November 10, 2013 that will work well too Quote Link to comment Share on other sites More sharing options...
williams Posted November 10, 2013 Author Report Share Posted November 10, 2013 There's no wd40 or gt85 ? Haha nope we don't. Soak it in petrol, then lube with a light oil Would the petrol used for a lawnmower be good enough? Quote Link to comment Share on other sites More sharing options...
Thehiphopsolidier Posted November 10, 2013 Report Share Posted November 10, 2013 wd40 säljs på jula m.m. Jag kör med bräkclean, funkar jätte bra och lämna det tills det dunstar bort och på med olja. Funkar varje gång. Quote Link to comment Share on other sites More sharing options...
williams Posted November 10, 2013 Author Report Share Posted November 10, 2013 Left it in some petrol for the night now. Can't wait for tomorrow when I'm building up the bike.. Quote Link to comment Share on other sites More sharing options...
forteh Posted November 10, 2013 Report Share Posted November 10, 2013 Lawnmower petrol will be fine, I assume it is a 2 stroke so will have extra oil in it which certainly won't hurt Quote Link to comment Share on other sites More sharing options...
williams Posted November 10, 2013 Author Report Share Posted November 10, 2013 Lawnmower petrol will be fine, I assume it is a 2 stroke so will have extra oil in it which certainly won't hurt Awesome cheers! Quote Link to comment Share on other sites More sharing options...
Trials-Mikey Posted November 12, 2013 Report Share Posted November 12, 2013 Awesome cheers! how well did the petrol method work ? Quote Link to comment Share on other sites More sharing options...
williams Posted November 12, 2013 Author Report Share Posted November 12, 2013 how well did the petrol method work ? Ehm good, the petrol was black with lots of dirt at the bottom, and it was quite loud! Good results Quote Link to comment Share on other sites More sharing options...
