Rockman Radix V2
SCOTTY___
Everybody,
Meet Raquel Radix. My singapore bride!
Spec:
Frame: Rockman Radix V2
Forks: Neon Training 24"
Headset: Onza Sealed Internal
Stem: TrialTech Race Forged 165*35 - Ti Fittings
Handlebars: Try-All Karbon
Cranks: TrialTech SL ISIS 165mm
Bottom Bracket: TrialTech SL Titanium
Bash Ring: TrialTech SL UCI Titanium Half Ring
Freewheel: Echo SL
Pedals: Try-All Elite Caged - Ti Axels & Cage Bolts
Chain: KMC z510HX
Chain Tension: TrialTech Snail cams (One Alloy / One Steel)
Front Rim: Echo TR 24"
Front Hub: Onza 2011 Sealed - Ti Fittings
Front Tyre: Schwable Mow Jow 1.85"
Front Brake: Magura HS33 2011 - Water Bled
Front Clamps: Magura Clamps with Echo SL Washers - Ti Bolts
Front Pads: TNN ADMs
Rear Rim: Echo TR 24"
Rear Hub: Echo TR 135mm Sealed - Ti Fittings
Rear Tyre: Schwable Fat Albert 2.4"
Rear Brake: Magura HS33 2011 - Water Bled
Rear Clamps: Magura Clamps with Echo SL Washers - Ti Bolts
Rear Pads: TNN Cousts
Weight: TBC
Thanks for looking.
Edited by SCOTTY___
  • Like 1
