crashbanggg Posted October 22, 2013 Report Share Posted October 22, 2013 Iv just built up my bike onto a new frame, however the head tube must be a lot longer as the steerer only reaches the middle of the top bolt (at a push) with no spacers between the headset and the stem (is that ok to do?) so looks like this: Is it ok to run it like that or will it all end in tears? Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted October 22, 2013 Report Share Posted October 22, 2013 Not ideal, but you'll likely be ok if you're not a particularly big/harsh rider. Make sure you have a long enough preload bolt in the top cap and if you can swap the fork/stem out at some point then get involved, but it'd keep you riding for a while at least. Other option is a headlock, if you can get your hands on one. Holds things together a little more firmly. Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted October 22, 2013 Report Share Posted October 22, 2013 The stem on my trials bike is worse than this and is fine. I can't see you having any troubles Quote Link to comment Share on other sites More sharing options...
wilf Posted October 22, 2013 Report Share Posted October 22, 2013 Yeah not ideal but it should be alright, I've ran one this short before without any problems. Quote Link to comment Share on other sites More sharing options...
aener Posted October 22, 2013 Report Share Posted October 22, 2013 If it's any consolation my trials bike has a very similar sized gap. Quote Link to comment Share on other sites More sharing options...
crashbanggg Posted October 22, 2013 Author Report Share Posted October 22, 2013 Thanks all! I'm a bit happier riding with it now! Quote Link to comment Share on other sites More sharing options...
Blake Posted October 22, 2013 Report Share Posted October 22, 2013 Bare in mind the gap will get a little smaller when you compress the headset. I've ran the same sized gap on my bike before with no beef ^^ Quote Link to comment Share on other sites More sharing options...
