dangerous bry Posted October 10, 2013 Report Share Posted October 10, 2013 Anyone ever tried it? If so, what's it like, anything like water? Cheers. Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted October 10, 2013 Report Share Posted October 10, 2013 hahaha sorry,but thats too funny. i dont know what baby oil is made from,but if it isnt mineral oil its likely to f*ck up the seals. silicone oils do,glycols like dot do. Quote Link to comment Share on other sites More sharing options...
dangerous bry Posted October 10, 2013 Author Report Share Posted October 10, 2013 It's a mineral oil! Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted October 10, 2013 Report Share Posted October 10, 2013 Tryed it.. it works but after a while the organic compounds break down and basically it all turns to sh!t.. Quote Link to comment Share on other sites More sharing options...
dangerous bry Posted October 10, 2013 Author Report Share Posted October 10, 2013 Cheers for the info;) Quote Link to comment Share on other sites More sharing options...
N.Wood Posted October 10, 2013 Report Share Posted October 10, 2013 Just use water and antifreeze bro. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted October 10, 2013 Report Share Posted October 10, 2013 ^^together they work, but either alone is temperature reactive Quote Link to comment Share on other sites More sharing options...
N.Wood Posted October 10, 2013 Report Share Posted October 10, 2013 Erm, thats why I said both. Just water also won't kill you, just might freeze up for like one month in a year. Antifreeze has rust inhibitors too. 1 Quote Link to comment Share on other sites More sharing options...
old boy chez Posted October 10, 2013 Report Share Posted October 10, 2013 Tried it didn't work well at all.. I now use power steering fluid never once had a prob . same brake For 7 years never at to bleed it once. Quote Link to comment Share on other sites More sharing options...
nicolasp1405 Posted October 10, 2013 Report Share Posted October 10, 2013 I'm using that in my saint and it works really well, you need the take the one that says parfume free... Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted October 10, 2013 Report Share Posted October 10, 2013 Erm, thats why I said both. Just water also won't kill you, just might freeze up for like one month in a year. Antifreeze has rust inhibitors too. Wasn't takin the piss, just sharing my findings.. I used the freezer to test. Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 10, 2013 Report Share Posted October 10, 2013 ^^together they work, but either alone is temperature reactive I had a pure antifreeze bleed (think it was a bottle of Halfords Antifreeze) and that worked absolutely fine for ages. I can't remember what happened to that brake in the end (I think I sold it, maybe...), but the seals and brake itself had no issues at all. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted October 10, 2013 Report Share Posted October 10, 2013 Yep it works fine untill about 5 - 10degrees, in an earlier post I showed a crack in my front lever... I've bled it that many times now the crack has gotten worse, unfortunatly the last thing I tried was wurths finest anti freeze, I darnt do another bleed as I'm pretty sure the crack will be a snap if I thighten the bleed screw again, so I'm stuck with it for a while. Point is I went out earlier and the brake lever wouldn't return propperly, same result in the freezer test, I keep my bike in the kitchen, within 5 mins it was fine again. Quote Link to comment Share on other sites More sharing options...
Yorkshire Dale Posted October 11, 2013 Report Share Posted October 11, 2013 Baby oil is for baby's and rubbing on boobies and nothing else 4 Quote Link to comment Share on other sites More sharing options...
old boy chez Posted October 11, 2013 Report Share Posted October 11, 2013 on boobies and nothing else Aaaameen 1 Quote Link to comment Share on other sites More sharing options...
