deivijs12 Posted October 4, 2013 Report Share Posted October 4, 2013 Im just wondering do rubber and foam grips not turn when you twist your wrist? I have nukeproof element lock on grips and had inspired ones and the bolts round so easily, so im looking for an alternative to rounding bolts Quote Link to comment Share on other sites More sharing options...
tom@eastcoasttrials Posted October 4, 2013 Report Share Posted October 4, 2013 trialtech foams hairspray, clear lacquer when fitting no movement Quote Link to comment Share on other sites More sharing options...
deivijs12 Posted October 5, 2013 Author Report Share Posted October 5, 2013 What about the rubber ones? Quote Link to comment Share on other sites More sharing options...
isitafox Posted October 5, 2013 Report Share Posted October 5, 2013 Same, just fit them with something like hairspray or spray paint to stick them onto the bars. They do have a habit of coming loose in torrential rain though most people wouldn't be riding in those conditions! Quote Link to comment Share on other sites More sharing options...
deivijs12 Posted October 5, 2013 Author Report Share Posted October 5, 2013 Do they move on their own though without paint or anything? Quote Link to comment Share on other sites More sharing options...
isitafox Posted October 5, 2013 Report Share Posted October 5, 2013 Some do, some don't, depends on the finish on the bars and the type of grip I find. I usually fit Trialtech foam grips to my trialtech bars dry and they're fine. Quote Link to comment Share on other sites More sharing options...
tom@eastcoasttrials Posted October 5, 2013 Report Share Posted October 5, 2013 if you dont wanna use paint ect wrap some insulation tape around the bar wet inside the grip slide on then squeeze the grip and let dry Quote Link to comment Share on other sites More sharing options...
dezmtber Posted October 6, 2013 Report Share Posted October 6, 2013 I just use disc brake cleaner on rubber Odi soft compound longneck grips. Once the disc cleaner evaporates its leaves a grease free stuck grip. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted October 7, 2013 Report Share Posted October 7, 2013 With my carbon try-all bars all the rubber grips i've used in the 3 years i;ve had the bars have been fine on a dry bar with no spray or anything. Forced on with air pressure. Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted October 8, 2013 Report Share Posted October 8, 2013 I too run carbon bars and plain Echo rubber grips and fit them dry. Use the track pump technique Quote Link to comment Share on other sites More sharing options...
315r Posted October 9, 2013 Report Share Posted October 9, 2013 Foam French ID or trialtech and hairspray for me works perfect, in different kinds of bars.. Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 9, 2013 Report Share Posted October 9, 2013 I used either satin black paint (as it matched the finish of the alloy bars I use/used) or clear lacquer (for carbon bars) and didn't really have any problems. The only times I really got throttle grip were with really old, haggard grips. If that happened I just put some lengthways strips of electrical tape on my bars and that took up any slack, so they tended to work fine. Quote Link to comment Share on other sites More sharing options...
trialsiain Posted October 10, 2013 Report Share Posted October 10, 2013 spit Quote Link to comment Share on other sites More sharing options...
dan rider g Posted October 10, 2013 Report Share Posted October 10, 2013 Does anyone use try all bar tape ? Are they worth getting ? Quote Link to comment Share on other sites More sharing options...
