Thebigjam101 Posted June 1, 2014 Report Share Posted June 1, 2014 Shimano Acura or whatever they're called, I just know them by there reg no. BR-M395. Brilliant stopping power from a budget pair of brakes, believe you can get a set £50-80 new. Wouldn't believe it from the quality you get from it, should be a lot more. Quote Link to comment Share on other sites More sharing options...
HippY Posted June 1, 2014 Report Share Posted June 1, 2014 RT66 180 front and back Avid Juicy 3, bled by me, and after 1 year of hardcore abuse it still works! Shimano Deore. if you want to have good brakes on your proper bike get them. After tartydays, I did some DH(= went down on a big hill with laaarge speed) and when I pressed the rear brake, the braking power was immense, sticky, especially from a £30 brake but probably a BB7 will come to the front (when I will have money from the bike, after my PC ) 1 Quote Link to comment Share on other sites More sharing options...
weebryan Posted June 1, 2014 Report Share Posted June 1, 2014 (edited) New racingline brakes, Tnn clamps and booster and tnn beegreens Edited June 1, 2014 by weebryan Quote Link to comment Share on other sites More sharing options...
bing Posted June 1, 2014 Author Report Share Posted June 1, 2014 They ok and not leak? Heard a few horror stories like Quote Link to comment Share on other sites More sharing options...
jack dickinson Posted June 1, 2014 Report Share Posted June 1, 2014 (edited) They ok and not leak? Heard a few horror stories like everyone's seem to be really spondy but i run standard maggie 05 (four finger blade) w/racingline piston on back and heatsink yellows in tnn cnc backings, very dead grind and a bit of tar. crazy bike cnc washerless clamps saint w/saint rotor on the front Edited June 1, 2014 by jack dickinson Quote Link to comment Share on other sites More sharing options...
trialsbikingnunn Posted June 1, 2014 Report Share Posted June 1, 2014 (edited) 04 raceline maguras front and back both with racingline alloy pistons, braided crossovers, heatsink yellows in cnc backings on back and cousts in plastic backings on front, echo tr washerless clamps front and back and smooth rims. best setup I've ever had and works amazingly with some tar added Edited June 1, 2014 by trialsbikingnunn 1 Quote Link to comment Share on other sites More sharing options...
bing Posted June 1, 2014 Author Report Share Posted June 1, 2014 Not that far out in terms of setup then are we dude Quote Link to comment Share on other sites More sharing options...
dann2707 Posted June 1, 2014 Report Share Posted June 1, 2014 Every racing line lever body and lever I've tested feels horrendous. So much flex it's unreal Quote Link to comment Share on other sites More sharing options...
dezmtber Posted June 1, 2014 Report Share Posted June 1, 2014 I am still running the same hope trialzones from two years ago. Still feel new Quote Link to comment Share on other sites More sharing options...
SamKidney Posted June 1, 2014 Report Share Posted June 1, 2014 Shimano Acura or whatever they're called, I just know them by there reg no. BR-M395. Brilliant stopping power from a budget pair of brakes, believe you can get a set £50-80 new. Wouldn't believe it from the quality you get from it, should be a lot more. Can vouch for this. Mine were 60 off eBay new, with rotors. Used them on my Kona Cinder Cone, which was my commuter to work, but being a small frame it was fun to trials on! 26" wheels and 160mm rotors front and rear, worked more than well enough to ride trialsy on. Superb budget brakes for sure, love mine Quote Link to comment Share on other sites More sharing options...
Thebigjam101 Posted June 2, 2014 Report Share Posted June 2, 2014 Can vouch for this. Mine were 60 off eBay new, with rotors. Used them on my Kona Cinder Cone, which was my commuter to work, but being a small frame it was fun to trials on! 26" wheels and 160mm rotors front and rear, worked more than well enough to ride trialsy on. Superb budget brakes for sure, love mine i was suprised myself! Especially on a full on trials, I haven't had any issue with stopping power. So easy to bleed too, I got mine for £35 for the pair off eBay. Such a good buy. Quote Link to comment Share on other sites More sharing options...
Jake. Posted June 2, 2014 Report Share Posted June 2, 2014 04 magura rear. Trialtech sport in heatsink backings. Echo washer less clamps. Water bleed. Sd7 vee front, deore arms. Cousts. Some random cable. Both on a year old dead grind which I should fix really, get a lot of pad slippage.Mainly on the rear, front is always deadly. Quote Link to comment Share on other sites More sharing options...
valk Posted June 2, 2014 Report Share Posted June 2, 2014 (edited) Oh well: Front: Magura 2004 hs33 Lever. hs33 slaves. Cousts with alu backings. Water Bleed. No Booster Rear: Magura hs11 full brake 4 finger lever blade. Cousts with alu backings. Oil Bleed. Jaf Booster Edited June 2, 2014 by valk Quote Link to comment Share on other sites More sharing options...
Blake Posted June 2, 2014 Report Share Posted June 2, 2014 04 magura rear. Trialtech sport in heatsink backings. Echo washer less clamps. Water bleed. Sd7 vee front, deore arms. Cousts. Some random cable. Both on a year old dead grind which I should fix really, get a lot of pad slippage. Mainly on the rear, front is always deadly. Grind that rear rim and you'll spunk your pants Quote Link to comment Share on other sites More sharing options...
