bing Posted September 23, 2013 Report Share Posted September 23, 2013 Just out of interest, what setups do people run? After seeing countless debates about maggie vs disk, 2finger vs 4finger, oil vs water. Put a picture of your handlebars from straight on and a brief description of your setup. Be good to see the variations. I'll start Front brake: 2012 shimano deore, 203mm Aztec rotor Rear brake: 2011 hs11, 4 finger lever, oil bled, cousts Quote Link to comment Share on other sites More sharing options...
hezzay Posted September 23, 2013 Report Share Posted September 23, 2013 Front: Avid BB7 w/ cleansweep 160mm rotor, will order a 180mm soon. Rear: Magura 2011 HS33 oil bled w/ CNC heatsink yellows Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted September 23, 2013 Report Share Posted September 23, 2013 My god, your brake levers look almost past vertical?! How do you even hold on? 1 Quote Link to comment Share on other sites More sharing options...
hezzay Posted September 23, 2013 Report Share Posted September 23, 2013 My god, your brake levers look almost past vertical?! How do you even hold on? Played around with the setup, this is what felt best with my ginormous fingers. ;p Quote Link to comment Share on other sites More sharing options...
trialsiain Posted September 23, 2013 Report Share Posted September 23, 2013 Mod- trialszone rear with mono trial rotor. 160mm - carbon/ti monotrial front with trialzone rotor.160mm Stock - Dual magura, water bled , cousts on rear and lgms on front. Quote Link to comment Share on other sites More sharing options...
Blake Posted September 23, 2013 Report Share Posted September 23, 2013 Some slaves a lever, couple of pads. 1 Quote Link to comment Share on other sites More sharing options...
pjl1984 Posted September 23, 2013 Report Share Posted September 23, 2013 Wont let me put a pick up but running hope tech 2 levers with x2 calipers 180mm rotors all seems good so far Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted September 23, 2013 Report Share Posted September 23, 2013 (edited) Front. Limey Echo TR lever, Magura cylinders, Coust (plastic) pads Water Bleed Rear Echo Original "dengura" lever Magura cylinders, Coust (plastic) pads Water Bleed Best setup I have used in a very long time, people think the echo levers leak, it is the cylinders that leak, all my levers have been perfect. only thing I hate is having a noisy front brake. on my marino I have front TR disc, and TR rim on rear with heatsink yellows on a smooth rim. good in dry weather. The rear TR brake does leak when bled with water, from the calipers (again), so just bleed with oil and it is fine. Edited September 23, 2013 by Ash-Kennard Quote Link to comment Share on other sites More sharing options...
isitafox Posted September 23, 2013 Report Share Posted September 23, 2013 Front: Magura MT2, 183mm JAF rotor Rear: Echo SL lever body, Magura 4 finger blade, water bleed, Trialtech pads in Heatsink backings. Both brakes are amazing. Quote Link to comment Share on other sites More sharing options...
bing Posted September 23, 2013 Author Report Share Posted September 23, 2013 You back riding now dude? I did the comp yesterday, it was bloody hard. Bike was fine, but I'm well unfit Quote Link to comment Share on other sites More sharing options...
isitafox Posted September 23, 2013 Report Share Posted September 23, 2013 Yeah, was gonna give you a bell last night but was mega busy after tea with small people. Add to that the fact I can't get a phone signal inside the house and was knackered so I ended up asleep on the sofa! Quote Link to comment Share on other sites More sharing options...
SamKidney Posted September 23, 2013 Report Share Posted September 23, 2013 (edited) Front and rear 2005 Maguras. Water bleeds, 4 finger levers. Front standard magura clamps ground down to be used washerless Rear Echo TR clamps. Front Rockman Blue material in Heatsink backings Rear Cousts. They're very good. Edited September 23, 2013 by Echo Lite 09 Quote Link to comment Share on other sites More sharing options...
dezmtber Posted September 23, 2013 Report Share Posted September 23, 2013 Dual trialzone with 180 rotors Quote Link to comment Share on other sites More sharing options...
AkuskaUK Posted September 23, 2013 Report Share Posted September 23, 2013 Front Hope Tech V2 with 203mm Hope saw and rear water bled '05 Maggie with TNN pads Quote Link to comment Share on other sites More sharing options...
Perez Posted September 24, 2013 Report Share Posted September 24, 2013 Front XTR disc brake with Ashima 160mm rotor, Rear 05 magura with 4 finger lever, oil bleed always, and Rockman blue pads with alu backing. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted September 24, 2013 Report Share Posted September 24, 2013 (edited) Race lines with some sh!t red pads.. only reason i posted was because i tweaked the leavers a bit in the vice, they squashed ring fingers (no pun) on a good squeeze. Minters now * oops you can see my pussy Edited September 24, 2013 by f**megently Quote Link to comment Share on other sites More sharing options...
dezmtber Posted September 24, 2013 Report Share Posted September 24, 2013 It's a tom cat its ok Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted September 24, 2013 Report Share Posted September 24, 2013 got no other pic of the actual setup: atm its front deore 596 disc,organic original pads,180mm xt rotor from 2009 rear hs33 2009,4-finger blade,echo cnc clamps,selfmade pads Quote Link to comment Share on other sites More sharing options...
N.Wood Posted September 24, 2013 Report Share Posted September 24, 2013 Race lines with some sh!t red pads.. only reason i posted was because i tweaked the leavers a bit in the vice, they squashed ring fingers (no pun) on a good squeeze. Minters now * oops you can see my pussy Coulda just moved the levers inboard a bit. Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted September 24, 2013 Report Share Posted September 24, 2013 I laughed a lot at this. Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted September 24, 2013 Report Share Posted September 24, 2013 Water bleeds. 04 levers. TNN Clamps and booster on the rear with LGMs on an everlasting grind. Rear plastic hose. Echo washerless clamps with Phat pads on the front with neverending grind. Front Unex hose. Quote Link to comment Share on other sites More sharing options...
isitafox Posted September 24, 2013 Report Share Posted September 24, 2013 What you got on the back of the Marino Ross? Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted September 24, 2013 Report Share Posted September 24, 2013 04 lever. Water bleed. Plastic hose. Magura clamps with plastic washers. Carbonique 2 bolt booster. Koxx browns. I should probably be using some sort of TNN pad on that bike but they're too grabby for manuals. Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted September 24, 2013 Report Share Posted September 24, 2013 I laughed a lot at this. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted September 24, 2013 Report Share Posted September 24, 2013 Quote Link to comment Share on other sites More sharing options...
