bing Posted September 20, 2013 Report Share Posted September 20, 2013 My rear mag was leaking, so I rebled and nipped all the fittings up so it wouldn't leak again. However the lever went soft within an hour of riding. A full strip down revealed a broken fitting at the slave end of the braided hose. I have since given it all a good clean and purchased a length of hope hose from crc. However reading the tartys website it says this won't work with magura fittings. I have the hope olives and hose insert, I don't see the problem. Can anybody shed any light on this. Techy bods help please Dan Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted September 20, 2013 Report Share Posted September 20, 2013 (edited) magura hose is low pressure vinyl tube,hope hose is high pressure disc tube with fibre reinforcement carcass the inner diameter of the hope hose should be fairly small,you couldnt move the amount of oil a low pressure brake moves. youd press the lever and the brake would drag like a syringe for example,you release it,same game Edited September 20, 2013 by FamilyBiker Quote Link to comment Share on other sites More sharing options...
bing Posted September 20, 2013 Author Report Share Posted September 20, 2013 They look about the same to be fair, and I have the right fittings, the only mag part would be a shroud nut. Quote Link to comment Share on other sites More sharing options...
customrider-Rhys Posted September 20, 2013 Report Share Posted September 20, 2013 the hose bores are different.. it just wont work, and if buy some miracle it does it will feel shit Quote Link to comment Share on other sites More sharing options...
bing Posted September 21, 2013 Author Report Share Posted September 21, 2013 Solved the problem. f**ked the 05 off and bought a full brand new set of 2011 hs11's, for the princely sum of £90. Got 4 finger levers as well which is a bonus Quote Link to comment Share on other sites More sharing options...
pjl1984 Posted September 21, 2013 Report Share Posted September 21, 2013 Have you got them set up now then m8? Quote Link to comment Share on other sites More sharing options...
bing Posted September 21, 2013 Author Report Share Posted September 21, 2013 Yes pal all done and working Quote Link to comment Share on other sites More sharing options...
pjl1984 Posted September 21, 2013 Report Share Posted September 21, 2013 Good one fella u can enjoy ur riding now Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted September 21, 2013 Report Share Posted September 21, 2013 you really replaced your brake for just the hose being wrecked? and for a 2011? and you had a 2004/5? Quote Link to comment Share on other sites More sharing options...
bing Posted September 21, 2013 Author Report Share Posted September 21, 2013 It wasn't the hose in the end, I replaced all the hoses and crossovers, fittings and olive, tried 2 sets of slaves and it still went soft at the lever. Upon closer inspection the lever body is cracked. So I bought a brand new full set and left them oil bled. The feel is a little bit softer than I'm used to, but it'll be reyt. At least I have leak free working brakes now, with 4 finger levers as a bonus Quote Link to comment Share on other sites More sharing options...
chris_trials Posted September 23, 2013 Report Share Posted September 23, 2013 Ive found the 2 finger levers have the best feel with the 2011 hs33 Quote Link to comment Share on other sites More sharing options...
