04 Magura lever help.
Jake.
The bit the pen is on, how do I get it out/off? The circle thing appears to be holding it but it won't budge. Just noticed there's a split in the lever below that circle thing, does this render the lever useless?
I'm just curious as I'd like to run this lever as it's flat blade to see if it feels nicer than the standard 04 levers.
I wouldn't run that lever, as you pointed out the pivot housing has broken through, it's gone in the direction of the force so will do nothing but fail dramatically :(
Thought so, only just noticed after putting the picture up. Shame...
Anyone got 04 cnc flat finger levers for sale? :)
