andyboy Posted September 14, 2013 Report Share Posted September 14, 2013 Hi all, I'm totally new to trials and this forum - just thought I'd put that out there. I've inherited most of the bits for an Onza T-Raptor. For some reason, all the bits for the Onza were swapped onto a jump-style frame. I'd like to build it back up to something like standard, have a play on it, and see how it goes (I might end up selling it when it's done). I've come here cos I'm not sure of the best way to re-assemble the Magura rim brakes, as I've never worked on a bike like this before. The front came looking like this: There is also a fork brace. Is this ok as it is? Should I re-attach the fork brace? The back brakes currently looks like this: There's also these mounts: Should I swap the mounts to the black ones when I put them on the Onza frame? Do I need the brace? What's the lever for on the silver mounts? Thanks in advance for your help! Quote Link to comment Share on other sites More sharing options...
andyboy Posted September 14, 2013 Author Report Share Posted September 14, 2013 Also - does anyone know what the bottom headset bearing is on the T-Raptor? I'm definitely missing one of these. I'm sure I could look it up, but this way is easier.... Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted September 14, 2013 Report Share Posted September 14, 2013 The 'lever' on the silver mounts is part of the v brake mount clamp, youll know what to use when you look at the frame, itll either have a v brake lug or s maggie mount like the forks. Braces are always good. Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted September 14, 2013 Report Share Posted September 14, 2013 if your frame has the same mounts as the fork i´d recommend using the black mounts.if so,get a decent brake booster for the rear brake,thats how the "brace"is really called. theyre much beefier than the original magure booster and give a stiffer braking feel. also i´d recommend the search function,those kinds of topics are really often here Quote Link to comment Share on other sites More sharing options...
andyboy Posted September 15, 2013 Author Report Share Posted September 15, 2013 Thanks for the answers, was exactly the info I was after. I did have a search first, but couldn't find anything. Quote Link to comment Share on other sites More sharing options...
