True Wheels, how important?
DeeDougie
I've bought a 2nd hand bike and I've just done my first bleed on my rear hs11 brake.
Its apparent that the rear wheel isn't completely true and a slight "buckle" can be seen when its in free wheel.
The brake is still awful and spongy and I think I've established new pads are required because I cant seem to line them up close enough to the rim.. but im assuming the true-ness of the wheel is still going to be an issue with rubbing new pads!?!....
How important is a true wheel in trials? Obviously it plays a big part in road racing but with all of the drops gaps hops and explosive riding etc is it going to be a persistent problem or will new pads generally be the answer or is a combo of the both needed.
Thanks in advance gents!
I JUST WANT TO GET OUT RIDING haha brand new to trials and I've not been able to ride yet!
Edited by DeeDougie
My wheels never stay true for more then a couple of rides, but as soon as they start to get loose I noitice it!
When I pedal hard the wheel turns (probably sound stupid but I cant think of a better way of puting it) so the rim touches the pad on one side, making it harder to pedal.
So the more power I put into a move the less power I actually get out of the bike, if that makes any sense.
Normal rolling around and doing rolling moves is not as much of a problem.
the spongyness might be down to the bleed mate trappee air give it a re bleed and try again
to be honest I don't think it is the bleed buddy. as soon as I touch the lever the pads move.. I just think the brake setup is wrong and the pads are too worn!?..
Do I need new pads or the double whammy of true wheel AND pads?
my wheels have been really buckled in the past...just set your pads further away.
but then I don't get any bite!?... eg. too spongy.
Spend a few quid on a spoke key and learn to true your wheel off youtube or google, easy enough to do.
'Triffic! thanks I'll Have a look now!..... Im assuming then that its pretty important to keep them true?
Edited by DeeDougie
use new washers on the calipers as well, as it makes setting up a brake much easier, and will prevent your calipers from being out of line and wearing your pads funny. keeping your wheels true and ensuring the spokes are all kept to a good tension will extend the life of your wheel; it gets easier to do it and it's a handy skill.
