Neon-trials Posted September 29, 2013 Report Share Posted September 29, 2013 do you have any answers to why people don't braze frames? It's stronger weld yeah In my trade nothing's brazed . Tig is a really strong weld ' an inch weld should hold a tonne in weight . Also brazing /gas welding is we're tig welding originated from . Before tig there was gas welding it's basically a crude less refined way of tig welding. Bronze braising/ gas welding is a strong weld I agree and the bronze it self is soft witch allows the joint to flex a little more without cracking + the fact that the weld is at least 4 times wider than most tig welds on a bike frame. I can tig/gas weld / braise so it will be down to customer choice But in the grand scheme of things tig is best in my opinion . Strong Clean Less perpetration time And bronze/silver solder rods are mega expensive too Ur right about the heat though it uses less heat to braise than it does to tig weld witch is good for not putting residual stress in the metal Other than that I can't offer any more I hope this helps Regards leigh Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted September 29, 2013 Report Share Posted September 29, 2013 In my trade nothing's brazed . Tig is a really strong weld ' an inch weld should hold a tonne in weight . Also brazing /gas welding is we're tig welding originated from . Before tig there was gas welding it's basically a crude less refined way of tig welding. Bronze braising/ gas welding is a strong weld I agree and the bronze it self is soft witch allows the joint to flex a little more without cracking + the fact that the weld is at least 4 times wider than most tig welds on a bike frame. I can tig/gas weld / braise so it will be down to customer choice But in the grand scheme of things tig is best in my opinion . Strong Clean Less perpetration time And bronze/silver solder rods are mega expensive too Ur right about the heat though it uses less heat to braise than it does to tig weld witch is good for not putting residual stress in the metal Other than that I can't offer any more I hope this helps Regards leigh Good answer. On a diffrnt note, if the frame were aged/heat treated and nitrided would the weld need to be of the same metal? 1 Quote Link to comment Share on other sites More sharing options...
Revolver Posted September 29, 2013 Report Share Posted September 29, 2013 Less perpetration time I think there should be equal opportunities for welds regardless of how much criminal activity they have been involved in. Quote Link to comment Share on other sites More sharing options...
Blake Posted September 30, 2013 Report Share Posted September 30, 2013 That +100 bike should die 3 Quote Link to comment Share on other sites More sharing options...
customrider-Rhys Posted September 30, 2013 Report Share Posted September 30, 2013 In my trade nothing's brazed . Tig is a really strong weld ' an inch weld should hold a tonne in weight . Also brazing /gas welding is we're tig welding originated from . Before tig there was gas welding it's basically a crude less refined way of tig welding. Bronze braising/ gas welding is a strong weld I agree and the bronze it self is soft witch allows the joint to flex a little more without cracking + the fact that the weld is at least 4 times wider than most tig welds on a bike frame. I can tig/gas weld / braise so it will be down to customer choice But in the grand scheme of things tig is best in my opinion . Strong Clean Less perpetration time And bronze/silver solder rods are mega expensive too Ur right about the heat though it uses less heat to braise than it does to tig weld witch is good for not putting residual stress in the metal Other than that I can't offer any more I hope this helps Regards leigh Thanks for the detailed reply, alot off what you say makes sense, I do see that tig is a cleaner weld and less messy. I heard that braize is harder weld than tig? If there was the option I think I would choose braize from my knoledge on it in the agricultural trade.. And the fact the weld will flex more is better surely? Less likely to crack on the welds like every other frame does. Rhys Quote Link to comment Share on other sites More sharing options...
dezmtber Posted September 30, 2013 Report Share Posted September 30, 2013 That +100 bike should die Why? Are u jealous of it Quote Link to comment Share on other sites More sharing options...
dann2707 Posted September 30, 2013 Report Share Posted September 30, 2013 lol Quote Link to comment Share on other sites More sharing options...
The Mechanic Posted September 30, 2013 Report Share Posted September 30, 2013 Interesting talk about Bronze welding, when I first started work making furnaces we made one for a company making bike frames. The prepared tubes went into the furnace and came out bronze welded,every joint was push fitted beforehand so a lot of preparation involved. It is a strong method of manufacture but for handmade frames not really practical unless you spend a great deal. Manufactures like Reynolds still recommend Bronze welding as well as TIG. Quote Link to comment Share on other sites More sharing options...
customrider-Rhys Posted September 30, 2013 Report Share Posted September 30, 2013 Interesting talk about Bronze welding, when I first started work making furnaces we made one for a company making bike frames. The prepared tubes went into the furnace and came out bronze welded,every joint was push fitted beforehand so a lot of preparation involved. It is a strong method of manufacture but for handmade frames not really practical unless you spend a great deal. Manufactures like Reynolds still recommend Bronze welding as well as TIG. But the to be fair if I was paying 300 odd pound for a custom frame and knew that bronze welding was better I would want it done.. No matter what extra preparation Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted September 30, 2013 Report Share Posted September 30, 2013 (edited) I saw this and i thought of you.. hehehe http://youtu.be/vQFmX-v2aWw start about 16 mins. mass production shite imo but bronze furnace style none the less. Edited October 1, 2013 by f**megently Quote Link to comment Share on other sites More sharing options...
The Mechanic Posted October 1, 2013 Report Share Posted October 1, 2013 I would think £300 for a handmade frame was fairly cheap, there is a lot of work involved. I have no idea what it would cost really but man hours alone without materials etc would put the price up. I never saw a completed bike after they had been through the furnace shipped off somewhere else to be assembled. Ideally its not just the welding either TIG or bronze which makes the frame part manufacture before welding is just as important, if I were to pay for a really good handmade frame I would like to see the standard of joints before they are welded, as you can hide a lot with a weld. Quote Link to comment Share on other sites More sharing options...
Trials-Mikey Posted October 1, 2013 Author Report Share Posted October 1, 2013 LET THIS THREAD DIE ! Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted October 1, 2013 Report Share Posted October 1, 2013 revive mine instead,need input on plastics Quote Link to comment Share on other sites More sharing options...
