Why Inspired frames have vertical dropouts?
clerictgm
Nothing more reliable than a good hub with a strong 10mm / 14mm axle bolt tightened with long wrench. If the frame is well made and the bolt sits perfect 90º on the dropout there's no problem at all. Mech hangers break and weigh more, inner bolts on the dropouts are equally bad because it's more prune to cracks after some abuse. Only advantage on mech hangers is the like manuel said, geo accuracy, but I rather prefer fiddling and changing chains after 4 months than bashing the tensioner.
Haha iv enjoyed reading this thread :) i ran a pro 2 on horzontal dropout without snail cams for ages. Wheel never moved so im assumeing that it was the "magic friction" that held it? Either that or my brute force tightening the wheel up?
  On 9/4/2013 at 3:09 PM, stirlingpowers said:
Horizontal, yes, my bad.
So magic friction it is, as I understand from your comments.
Awesome comment!! im still chuckling :) thanks for cheering up this very gloomy friday for me xx
definitly brute on that one. i run a pro 2 on snail cams and tryed alloy bolts on the cam bolts and bent the head on the bolt.
using steel now and all good.
have you been rounding off any of the m10 allen key bolt then with that much brute to hold the wheel?
  • Like 1
  On 9/4/2013 at 10:48 AM, Mark W said:
/\ Those are nice dropouts.
The original reason for it was to allow people to run gears if they wanted to. Quite a few riders who bought Fourplay and Hex frames from TartyBikes when I worked there were talking about running gears, and having vertical dropouts allows that. The Fourplay/Hex frames are supposed to be pretty versatile, so it just helps out in that sense. The Arcade is more focussed, so putting horizontal dropouts on there isn't as much of an issue.
You said everything :)
did do a couple yea so i put some stainless m10 bolts in that use a 17mm spanner instead of an allen key :) next ride my bro did the same and we have never looked back x
tell that to a bicycle technician.
oh wait!
:wink:
edit:no,joking aside,again(hehe), normally an axle bolt or nut is tightened to 30Nm,40 would be more than 130% of that,which exeeds most bolt or nut manufacturers tolerances already.should be enough
Edited by FamilyBiker
