Leaky Echo TR 2011 Rim break
Dušan
Hey guys,
I have a pretty new Echo TR 2011 rim brake, everything worked fine but my left brake caliper (or whatever is the thing with pistons pushing pads towards rim called) Is there any solution or should i just replace it?
I have plenty of spare parts from magura hs33 brakes. I could either build one complete magura hs33 05 brake with 4 finger lever (even have custom aluminium TPA lying around somewhere) or use hs33 brake calipers along with echo lever
Which way would you recommend?
Secondly how does echo levers get along with water bleeding? (haven't done waterbleed in a while so some resources on what's currently the best way would be helpful)
Thanks, Dusan
