zoster Posted August 30, 2013 Report Share Posted August 30, 2013 the title pretty much says it all... thanks for your input ! Quote Link to comment Share on other sites More sharing options...
Blake Posted August 30, 2013 Report Share Posted August 30, 2013 Spit and pull 1 Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted August 30, 2013 Report Share Posted August 30, 2013 Deodrant / hair spray Quote Link to comment Share on other sites More sharing options...
old boy chez Posted August 30, 2013 Report Share Posted August 30, 2013 Hairspray 2 Quote Link to comment Share on other sites More sharing options...
Neon-trials Posted August 30, 2013 Report Share Posted August 30, 2013 Clear laquer all the way just spray some down the grip and some on the bar and slide on and leave to dry then hey presto stuck like shit to a blanket . If that dosent work use electrical insulation tape round the bar n then repeat above method Regards Quote Link to comment Share on other sites More sharing options...
err Posted August 30, 2013 Report Share Posted August 30, 2013 hairspray 1 Quote Link to comment Share on other sites More sharing options...
crilin202 Posted August 30, 2013 Report Share Posted August 30, 2013 spit on it. nice and easy Quote Link to comment Share on other sites More sharing options...
shercofray Posted August 30, 2013 Report Share Posted August 30, 2013 Put a pump in the end of the grip and put the other end over the edge of the bar. Psh down on the pump and the air will escape out the other end of the grip allowing it to expand and slide onto the bar. I've always done this and never had any slip. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted August 30, 2013 Report Share Posted August 30, 2013 Roll them inside out on a broom stick. and pull 'em on like a johnny Quote Link to comment Share on other sites More sharing options...
dngr2self Posted August 30, 2013 Report Share Posted August 30, 2013 Make sure they're dry and slowly tap them on. Quote Link to comment Share on other sites More sharing options...
Ali C Posted August 30, 2013 Report Share Posted August 30, 2013 Clear laquer all the way just spray some down the grip and some on the bar and slide on and leave to dry then hey presto stuck like shit to a blanket . If that dosent work use electrical insulation tape round the bar n then repeat above method Regards exactly what I do Quote Link to comment Share on other sites More sharing options...
isitafox Posted August 30, 2013 Report Share Posted August 30, 2013 4 cable ties inside the grip, slide over the bar then pull the ties out. 1 Quote Link to comment Share on other sites More sharing options...
trialsiain Posted August 30, 2013 Report Share Posted August 30, 2013 Sounds nasty but spit, works a treat Quote Link to comment Share on other sites More sharing options...
weebryan Posted August 31, 2013 Report Share Posted August 31, 2013 To get off cheap deodorant dosent evaporate too quickly To put on electrical contact cleaner leaves no residue and drys in seconds, use it on any type of grip, also get grips off easy cause there not glued on for futer replacement using this method 1 Quote Link to comment Share on other sites More sharing options...
dave33 Posted September 2, 2013 Report Share Posted September 2, 2013 Airline Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted September 3, 2013 Report Share Posted September 3, 2013 +1 for the trackpump/airline method Quote Link to comment Share on other sites More sharing options...
Blake Posted September 3, 2013 Report Share Posted September 3, 2013 If spit takes too long use disk brake cleaner. Quote Link to comment Share on other sites More sharing options...
Sam Nichols Posted September 3, 2013 Report Share Posted September 3, 2013 Airline Too many hidden costs. 3 Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted September 3, 2013 Report Share Posted September 3, 2013 I use the cheap hair spray method on my alloy bars. Does it dry in and stick as well on Carbon bars? Would the hair spray do anything to the carbon? I'm guessing not but... Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 3, 2013 Report Share Posted September 3, 2013 Seems like you can pretty much use anything on carbon bars really - I've used spray paint, lacquer and grip glue before, and I'd imagine they'd do more potential damage than hairspray would be able to. You should be good to go really. In terms of sticking to stuff, whatever works on alloy seems to work as well on carbon for me. The only difference comes with grips really - I usually just use a bit of GT-85 or similar for rubber grips, but always spray paint/lacquer for foam. Quote Link to comment Share on other sites More sharing options...
JDâ„¢ Posted September 3, 2013 Report Share Posted September 3, 2013 Too many hidden costs. http://www.youtube.com/watch?v=NsusRzjk8b0 Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted September 3, 2013 Report Share Posted September 3, 2013 aha-haaaa! you sir made my day Quote Link to comment Share on other sites More sharing options...
