Should I degrease it?
clerictgm
"This freewheel must be bedded in before trials use, to ensure any grease used when assembling the freewheel works away from the mechanism. If the freewheel is subjected to trials use without having been bedded in, the pawls will not engage correctly and this causes the freewheel to skip, damaging the pawls and ratchet. If you wish to speed up this process, you can thin the grease down with light oil like GT85 or WD40. Failure to bed the freewheel in correctly will void the warranty."
Tarty should really make a video or a short text about how to bed in these greased freewheels.
Must + no instructions is a combination that has kept me off buying one.
I won't rely on any information on the forum here, only on instructions
given by those who will decide on my warranty claim.
funny,hope has oiled ratchets for trials use but the dedicated trials companies grease their ones.
on my hub bedding in was to tighten up the ratchet ring,simples
but to answer your question,flush it through with a silicon based oil,then ride it for a few hours without doing trials use,thats hardening up the pawls surfaces and pushes away excess grease from the ratchet ring
Edited by FamilyBiker
So, I opened the cap and washed away all the grease with WD40. Then I screwed the cap back.
1) FW sound became sharper.
2) If I shake FW it sounds like rattle - Is it BAD or OK? (it's bearings).
Edited by clerictgm
Yeah bearings will rattle because there is a small gap in them to allow them to move freely.
Now you've thinned out the grease take the bike for a ride around for a few hours before you use it for trials.
Got to agree really, seems a littel off demanding that a product has to go through a certain process before it is to be used for it's intended purpose and then not explaining how you should do this. I appreciate to some that bedding in a freewheel might be an obvious thing to do and they will know how to do it, but i'm sure that to a lot people, it's not obvious and they aren't sure what it entails. Can't do any harm to Tarty really.
it's like getting in a brand new car and red-lining it
There is a school of thought that thinks that's an alternative way to run an engine in... When I got my Kwak I did a partial 'hard run in' just for shits and giggles. Doubt it made any difference but there you go!
Edit: But that doesn't go for trials hubs/freewheels. Soft break in is a must.
The grease is generally put in to make assembly easier as it holds the open bearings in place better so it's not too comparable to a Hope in that sense. That said, Echo are doing it right.
Soooooo. After dergreasing and stuff, I rode for 2 hours. Street without trials. But when I tryed once to get on back wheel and do few little pedal kicks FW SKIPPED! WTF? It was only once bud I don't think it's a good sight.
So what do you think? FW is SHIT and must be replaced or what?
My ECHO FW lasts 1 year without any bedding in at the start of using and no problem untill now.
WTFTFTF. I buyed new one and want i to work at least 1 year without problems.
Edited by clerictgm
But the point of bedding a freewheel in is to knock and burrs off the pawls and get the pawls to seat correctly in the drive ring. To do this you need to actually free-wheel around, that is roll at speed without pedalling. Pedalling continuously for 2 hours will do nothing to bed a freewheel in but coasting down a huuuuuge hill for 2 hours would, especially if you pedal at random intervals to ensure the pawls get a chance to fully engage properly and get themselves seated. Hope that makes sense.
In other news, change to rear freewheel and buy a Hope Pro2 :P.
How to bed in a freewheel.
You will need:
1 bike, with new freewheel attached (FFW or freehub, this how-to is all inclusive)
1 treadmill
Step 1: Place bike on treadmill
Step 2: Sit/stand on bike (or you could just secure it upright for extra man points)
Step 3: Turn on treadmill. Don't be shy.
Step 4: ???
Step 5: Profit.
  • Like 2
+1 for Hope pro 2 hub(going on 6th year now, no problem (just a little dig in in the cassettebody from sprockets..))....To me all this bedding in, just indicates that Freewheels are crap out of the box, (and stay that way :-)....)...
