fruitbat Posted August 26, 2013 Report Share Posted August 26, 2013 (edited) As part of me trying to get back onto a trials bike at 30 I have dug around in my shed. I have found some forks which I believe are some fairly old Onza forks. They were the ones that allowed you, with an adapter, to use them on either 24 or 26 inch wheels. Below is a picture of the brake mounts. I am looking for the adapters if anyone knows where I can get some. I have already contacted Onza to see if they can help (if they are their forks), but will also see who here can help. Looking for both the V-Brake mounts (rounded silver blocks and the brake mount bolt) or the magura mount adapter (just a small silver block that fits into the grove, and is then used with 4 bolt adapters) If anyone does have any, please can you provide pictures so I can make sure they are what I need, plus let me know what they want for them (I know this is sort of a wanted post, but also looking for advice if someone can point in right direction for item) Thanks in advance Edited August 26, 2013 by fruitbat Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted August 26, 2013 Report Share Posted August 26, 2013 Dimension from bottom of groove totop of mount and pm me and I can make you some Quote Link to comment Share on other sites More sharing options...
