Hs33 master (lever) piston stuck
Topsy
Silicone grease has less drag than vaseline, has a much higher temperature range and is recommended for most brake piston rebuild kits. (Not trying to be a smartarse)
its not cheap. About 10-20 quid for a toothpaste sized tube of the good stuff.
If you are going to water bleed a metalpiston you'll need something like that to stop the corrosion (unless its stainless ect)
Edited by f**megently
