Hs33 master (lever) piston stuck
Topsy
When you're saying attached a bleed hose to a track pump. How do they connect? My bleed hose has a screwed end for the lever and an open end which I push a syringe onto...
Can someone post a picture or video please?
Push it into one of your holes ;) you like that.
what a noob...put the hose into the schrader valve hole, turn the lever to hold it in place like a valve and pump like a boss.
PSI is Pounds per Square Inch, it's a measurement of pressure rather than flow rate or movement of a volume of air :) So you could get a million PSI through a tube 1mm in diameter (in fact smaller diameters are better at holding larger pressures).
Got mine out with 116 psi. Was great fun haha.
Now, would anyone be interested in some aluminium pistons? I'd have thought they should not swell and get stuck?
I might be able to do some :)
Only thing that looks like it could be tricky is that orange seal/ring.. Wouldn't know how I could get hold of anything like that, the O ring shouldn't be a problem though.
Edited by Hopping_Topsy
  • 3 weeks later...
