Trials-Mikey Posted August 5, 2013 Report Share Posted August 5, 2013 (edited) Recently my slick maxxis creepy crawler has worn through to the canvas and i am in need of a new tyre. I ride alot of brakeless, from looking around i have narrowed it down to two choices either a kenda small block 8 or and maxxis holy roller and i was just wondering if anyone here has experience from running either of these tyres thanks. Edited August 5, 2013 by Trials-Mikey Quote Link to comment Share on other sites More sharing options...
harmertrials Posted August 5, 2013 Report Share Posted August 5, 2013 You worried about weight? If not get a maxxis hookworm, practically stab proof. Quote Link to comment Share on other sites More sharing options...
Trials-Mikey Posted August 5, 2013 Author Report Share Posted August 5, 2013 You worried about weight? If not get a maxxis hookworm, practically stab proof. no not really as long as its relatively light. thanks ill check it out Quote Link to comment Share on other sites More sharing options...
harmertrials Posted August 5, 2013 Report Share Posted August 5, 2013 no not really as long as its relatively light. thanks ill check it out Very weighty tyre, but honestly the wear life, punny resistance and the way they roll will more than make up for it. Cheap too. Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted August 5, 2013 Report Share Posted August 5, 2013 I'd go for the kenda! Much nicer compared to the Maxxis. Friend had one of the front and i didn't really rate it opposed to kenda which i was running for a short period Quote Link to comment Share on other sites More sharing options...
Blake Posted August 5, 2013 Report Share Posted August 5, 2013 I run a holy roller and it's great for street. Quote Link to comment Share on other sites More sharing options...
harmertrials Posted August 5, 2013 Report Share Posted August 5, 2013 http://www.chainreactioncycles.com/maxxis-hookworm-bmx-tyre/rp-prod11547?ModelID=11547 1 Quote Link to comment Share on other sites More sharing options...
bing Posted August 5, 2013 Report Share Posted August 5, 2013 2.1 small block 8 for the win Quote Link to comment Share on other sites More sharing options...
dezmtber Posted August 5, 2013 Report Share Posted August 5, 2013 I used to run a schwalbe mow Joe up front on the mod. Worth looking at there very nice. Quote Link to comment Share on other sites More sharing options...
Neon-trials Posted August 5, 2013 Report Share Posted August 5, 2013 I'm really impressed with my small block 8 the grip is hellish in the dry and there well light and very bouncy Quote Link to comment Share on other sites More sharing options...
trialsiain Posted August 5, 2013 Report Share Posted August 5, 2013 small block 8, they look good too. Quote Link to comment Share on other sites More sharing options...
harmertrials Posted August 5, 2013 Report Share Posted August 5, 2013 Personally found the small blocks to be of absolutely no grip whatsoever 1 Quote Link to comment Share on other sites More sharing options...
trialsiain Posted August 5, 2013 Report Share Posted August 5, 2013 Personally found the small blocks to be of absolutely no grip whatsoever on the 24 mine was a lot better than rocket ron, no 24 front tyre is good though to be honest Quote Link to comment Share on other sites More sharing options...
harmertrials Posted August 5, 2013 Report Share Posted August 5, 2013 The rocket ron has to be the worst use of rubber ever though Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted August 5, 2013 Report Share Posted August 5, 2013 Small block 8 was one of the worst tyres i've ever used, no puncture resistance at all 1 Quote Link to comment Share on other sites More sharing options...
Blake Posted August 5, 2013 Report Share Posted August 5, 2013 Small block 8 was one of the worst tyres i've ever used, no puncture resistance at all This You don't need a lot in a front tyre unless you ride comps, then you want something like a try all or monty For street try get something with fat sidewalls for more puncture resistance Quote Link to comment Share on other sites More sharing options...
dann2707 Posted August 5, 2013 Report Share Posted August 5, 2013 I'm genuinely enjoying my creeper crawler. Seems to have the best of both worlds and works really well in the wet too. Sm8 are much lighter though Quote Link to comment Share on other sites More sharing options...
aener Posted August 6, 2013 Report Share Posted August 6, 2013 If you value your life even a little you won't get a Block8. Honestly the worst tyre I've ever had, shortly followed by the K-RAD. I currently have a Maxxis Grifter. It's fairly middle-ranged in weight, but has only washed out twice (in the wet) in the 18 months I've had it on. Yes - 18 months. The wear-rate is f**king awesome, without sacrificing much grip. They roll forever too, and I've only had three punctures with it on - all of which I fully deserved Slicked Crawlers, Montys and Try-Alls are all great too, but the semi-slick gives that little bit more grip in wet/dusty places. Considering winter's on the way, I'd try and avoid full-slicks 1 Quote Link to comment Share on other sites More sharing options...
cardenas_26trials Posted August 7, 2013 Report Share Posted August 7, 2013 I like my kenda, it's light and the grip is not thaaaat bad. Haven't had so many punctures neither. Only major problem I found is the wear-rate. Give it a try ! Quote Link to comment Share on other sites More sharing options...
Trials-Mikey Posted August 9, 2013 Author Report Share Posted August 9, 2013 If you value your life even a little you won't get a Block8. Honestly the worst tyre I've ever had, shortly followed by the K-RAD. Wish I had seen this before I called up tarty but hey ho ill give it a try and see. Have you had bad experiences with this tyre or what is it just generally not good ? Quote Link to comment Share on other sites More sharing options...
aener Posted August 9, 2013 Report Share Posted August 9, 2013 The Block8? Yeah... It nearly cost me my jaw. (Amongst a shit-storm of other, less terrifying but still very far from ideal instances.) 1 Quote Link to comment Share on other sites More sharing options...
Trials-Mikey Posted August 9, 2013 Author Report Share Posted August 9, 2013 The Block8? Yeah... It nearly cost me my jaw. (Amongst a shit-storm of other, less terrifying but still very far from ideal instances.) Well that's really making me consider running it. Looks like ill be on the second front tyre of this week hahahaha Quote Link to comment Share on other sites More sharing options...
trialsiain Posted August 9, 2013 Report Share Posted August 9, 2013 do you lot ride on ice mine was not even that bad to be honest on wet pallets Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 9, 2013 Report Share Posted August 9, 2013 Quite liked my Small Block 8. Grip was fine unless muddy, cheap, light... Flipp is weird Quote Link to comment Share on other sites More sharing options...
Trials-Mikey Posted August 10, 2013 Author Report Share Posted August 10, 2013 do you lot ride on ice mine was not even that bad to be honest on wet pallets yeah i stay on the concrete and tarmac so i should be fine hopefully. natty and me don't get on Quote Link to comment Share on other sites More sharing options...
