Marchi.uk Posted August 3, 2013 Report Share Posted August 3, 2013 Hi streeters, From when I mounted the Holyroller, I punch a lot of tubes, it's really boring change all times tubes and tubes! May be I used wrong pression inside the tyres, so how many bars are ok? Is that a common problem also for you, resulting from the Holyroller? Thanks. Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted August 3, 2013 Report Share Posted August 3, 2013 I run about 30psi (like 2.1 bar) in my holy rollers and don't get many punctures. Maybe try a DH tube and a bit more pressure though. Quote Link to comment Share on other sites More sharing options...
Marchi.uk Posted August 3, 2013 Author Report Share Posted August 3, 2013 (edited) thanks man. I ride at 2.2, with 2.1(2.5 airwave dh tubes. Are a bit more thick but not too much like a real DH tube, (may be too heavy). Tomorrow I try to put more pression inside, if continue may be I will try to change tyre, but I don't know which one can substitute my maxxis.. Many thanks for your reply. Cheers. Edited August 3, 2013 by Marchi.uk Quote Link to comment Share on other sites More sharing options...
ooo Posted August 4, 2013 Report Share Posted August 4, 2013 I puncture a alot as I'm not a smooth rider. I run 60 psi for street its much better for spins and speed, but Im not very trialsy. Try getting a 3 inch downhill tube, even saying that there is a big difference in wall thickness between different downhill tubes. I have some really thick ones but I cant remember who make them other downhill tubes aren't even half as thick. If those things don't help use a DMR Moto RT 2.4, its thicker and much heavier than a holy roller and feels much nicer to ride in my opinion (gripper and much more pop, rolls and corners nicer too). Quote Link to comment Share on other sites More sharing options...
Marchi.uk Posted August 4, 2013 Author Report Share Posted August 4, 2013 (edited) Thank you "ooo"... I bought just now a Tioga FS 100 Skidrow 2.3x26. Can be a good compromise between rolls/price/weight. So If work it's ok. If don't I will try the DMR...thank you for your suggestion. Edited August 4, 2013 by Marchi.uk Quote Link to comment Share on other sites More sharing options...
