SRBTrial 1 Posted August 2, 2013 Report Share Posted August 2, 2013 (edited) here i dont have many choise and this is closest to trial parts i can get here.Are they ok for trial noob?:)i want to do endoes,manuals,pivots,bunny hops...and other starter things.sry for bed eng. http://planetbike.rs/pbshop/Biciklizam/Delovi/Volani/2510/ http://planetbike.rs/pbshop/Biciklizam/Delovi/Vilju%C5%A1ke/2440/ http://planetbike.rs/pbshop/Biciklizam/Delovi/Nosa%C4%8Di%20volana/1554/ Edited August 2, 2013 by SRBTrial 1 Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted August 2, 2013 Report Share Posted August 2, 2013 What bike are they going on? do you know the geometry of it? Quote Link to comment Share on other sites More sharing options...
SRBTrial 1 Posted August 2, 2013 Author Report Share Posted August 2, 2013 its mongoose thunderball 2007 frame (http://www.google.rs/imgres?imgurl=http://www.moredirt.co.uk/bikes/21490.jpg&imgrefurl=http://www.moredirt.co.uk/ratemyride/bike_profile.php?id%3D21490&h=445&w=593&sz=48&tbnid=HZ9PEPv9uW0RHM:&tbnh=91&tbnw=121&zoom=1&usg=__vdyhCJj8Fzf_vIA-L6aOCIB0GAs=&docid=71hR7Buww-hn7M&sa=X&ei=ZqP7Ud61B-mH4ASjsICQAg&ved=0CDIQ9QEwAQ&dur=68#imgdii=HZ9PEPv9uW0RHM%3A%3BvikQBjY2NzCuKM%3BHZ9PEPv9uW0RHM%3A) its singlespeed i removed all from him and started building from scratch. Quote Link to comment Share on other sites More sharing options...
ooo Posted August 2, 2013 Report Share Posted August 2, 2013 (edited) I understand that you have limited access to trials specific parts and bikes, but there isn't loads you can do to setup that bike for 'pure' trials. However you can learn a lot of street mtb and do more of the old school trials. I think it is best to use that bike for what it is good for as you can do alot on that, there is loads of fun to be had. Firstly keep suspension forks on it, they are much longer which means if you put rigid forks on; the pedals on the bike will be too low (low bb) this will make doing any tricks difficult. As for bars what ever is comfortable for you. I would personally keep a short stem on that bike as it will make it better for streety moves. I think you should make sure you have the right ratios on your gears and know which gearing to use for trialsy stuff. Then also try and get the best rear brake you can. Look up more of these guys videos, if you havent seen them before: and this one: Edited August 2, 2013 by ooo Quote Link to comment Share on other sites More sharing options...
SRBTrial 1 Posted August 4, 2013 Author Report Share Posted August 4, 2013 ok thx for tips and videos,i will see what i can do with this bike to make it go and try that things to see what's good for me. Quote Link to comment Share on other sites More sharing options...
