dezmtber Posted July 24, 2013 Report Share Posted July 24, 2013 i was thinking maybe blanking the hole where the banjo fits with the m6 8mm bolt and one copper washer. then fitting a m6 straight fitting into the bleed hole, to get rid of the the old banjo hitting rocks problem. i know i would then have to bleed the brake by taking out the pads and just letting the m6 8mm bolt leak without a pipe attached. but the brake could hit rocks all it wants with no problems just not shure a straight connector will work on the bleed hole. anyone tryed this? Quote Link to comment Share on other sites More sharing options...
bing Posted July 24, 2013 Report Share Posted July 24, 2013 Yeah rob Poyser has done it with his rear hope, swapped the fittings round. He told us on that leek ride Quote Link to comment Share on other sites More sharing options...
Ali C Posted July 24, 2013 Report Share Posted July 24, 2013 yep, used to do it to every Hope brake I had Quote Link to comment Share on other sites More sharing options...
dezmtber Posted July 25, 2013 Author Report Share Posted July 25, 2013 Cheers lads I will get some fittings sorted today Quote Link to comment Share on other sites More sharing options...
