Another Zoot topic
HippY
Hey guys
Im planning to get a brand new bike and I have 2 choice: a brand new echo Pure 26 inch, front disc, rear Echo TR hydro rim, or a new Onza zoot from tarty.
I would like to go street trial but:
1. I am not sure if I can do streety moves. maybe I will learn them overtime, but I am not sure how start off street trials with a small trials knowledge.
2. I am not sure if it is my way. I tried out some BMX and I nearly cried. They are short, high, uncomfortable, although I am sure i can get used to them
How close is Zoots Geo to a BMX? I am not sure if it would worth the risk or not
The zoot won't feel anything like a bmx! I can't do bmx'y moves either, but I find the street-trial geo to be far more comfortable and enjoyable for casual trials-riding.
If, like me, you're not into doing big gaps etc then the zoot may feel better.
compared to inspired skye and fourplay the zoot feels alot more like the fourplay, easier on trial stuff but kinda though for bunny jumps/wheelies etc
a 75-90mm 35 degree stem makes it alot more fun for streety stuff though :)
actually I am not that type of person who says " yay, I beat my record, now I jumped an inch bigger!" I just like to enjoy things, like casually. there is the other side of me, but that is the geek "I need 3 monitors" part.
As I said, I would go more on reliability rather than lightweight ( my current bike is 10 kg and it is very light for me), what would be better: buy a brand new one, and use it in stock/small modification for a while, or get/built one and go with better parts? I would go with around 600 pounds, so it would be a new one with pads and postage, or go with a 300 hundred used one, change loads of bits?
I agree with the above the Onza has a pretty rounded geo and opens up to lot's of fun moves. I do feel that the build quality of the echo would be lots better (going from the spec of the zoot).
If you aren't that bothered about the wheel size for the price of an echo it would still be cheaper for you to get a Inspired Element that's a very reasonable build and has a pretty nailed down geo (and won't break like the others)
My budget will go as far as 5-600£, so other bikes fall out of the range, and Zoot seems like a good choice for me. Probably I am not going to brake it, I am a beginner
I misinterpreted what you said at the start in that case, I presumed either bike was going to come from tarty meaning your budget was higher.
that could be a valid point, that I work for a few more weeks and i will get an used inspired
It seems like it could be only a used one ( or if I get a waay more better job, a new one, then this topic would not have any meaning, but sadly that is not the situation yet)
would a used inspired around 600£ be better choice then a new zoot/used zoot with new parts?
or if you weight it by reliability, what is better, a new zoot and a frame set change later on or a used one and im changing the parts on the fly?
note, i do not have any 24" part
