geometry
OK, OK take the piss out of the new guy... Balloons could work though!
We aren't dude, just there's been hundreds of questions on the same things you have posted. Use the search function, all the info you need will be in past topics. Yes, put a grind on, or use a dab of tar. If you want a higher front end, get a higher stem with more upwards rake. Ie if its a 30, change it to a 35. Also high rise bars are things to think about, although you are looking at upwards of £40 for some decent trials geo bars, eg trialtech or rockman
