clerictgm Posted July 18, 2013 Report Share Posted July 18, 2013 I'm setting up vees to my Element and don't know what to choose: 1) Grinded rim (trialtech) + some hard pads (TNN?) or 2) Smooth rim + smooth pads (inspired fat) And also I'm very interested in that build http://www.trials-forum.co.uk/topic/177948-retired-element/?hl=retired Why Nick uses Flexy Noodles? And isn't element frame hard enough to not use booster? I have some expirience of using vees in trials on my because 24, it was avid sd7 + sd7 lever + inspired slim pads + echo tr rim with dead(erased) grind, hard noodle and some noname cables. So the result was pretty shitty and brake felt pretty bad plus there was almost no bite, and not so good hold. *There are almost no way for me to get good set of cables (odyssey or something linear) so maybe just to set up maggie with evo clamps? Quote Link to comment Share on other sites More sharing options...
Blake Posted July 18, 2013 Report Share Posted July 18, 2013 If you live in the snowy wasteland I wouldn't run smooth. Quote Link to comment Share on other sites More sharing options...
Shaun@FlawlessBikes Posted July 18, 2013 Report Share Posted July 18, 2013 It really depends if you are going to ride in wet weather, if not stay on smooth rims as grinds wear down and eventually you will have side walls on your rims that resemble foil, but like georgie poo said if you do live in a snowy waste land 'grind em up' Quote Link to comment Share on other sites More sharing options...
