How to use Onza's tensioner system properly?
dann2707
Hey.
I'm setting up my bike with the brakes and the chain tension to get everything perfect. It's the ice so it has inbuilt tensioners with the brug screws that go through the dropouts.
How are people using onza's tensioning system to it's full potential?
How do you know when the wheel is exactly in the middle? Atm i'm measuring the rims edge with a steel ruler referencing it to where the brake mounts are either side, is there a better place to measure?
Also I'm struggling when tightening it up, when I get it all perfect with the brakes and chain tension when I tighten up the hub bolts it just tightens towards one way and it's like I have to over compensate on one side, bit of a bast to explain at this time.
Basically how do you do it? Cheers
Edited by dann2707
Have the wheel as forward as it will go centre, Then set up the drive side first by gradually pulling the wheel back with the tensioners on that side. Also undo the hub bolts very slightly so there's just enough slack for the tensioners to work, But not enough the frame starts to bend outwards.
few simple little tips but so effective!
Edited by trials owns
  • Like 1
