Crewkerz Cleep !
laurent
This bike is incredibly stiff, if you are looking for stiffness, this is the bike you need.
Even not being a very good rider, i can appreciate how effective this bike is, and i can realise how much power is loss in each movment with bikes using ISIS Bottom brackets or such.
They've also done a lot of small improvments over the Quark 2 : Insert for the tensionner, rake mount and tyre arch, 1.5" steerer ...
In my opinion, this bike is THE most "modern" bike trial on the market.
This is a bike i highly recommand.
And Again Customer support is the greatest.
I had to deal with Christian in the past, to me he seem very passionate about what he does.
Quick Specs :
- Crewkerz Cleep long (1090/380/+65) frame and fork.
- Crewkerz Wheels
- Brakes : rear hs33 ("old" style) + 185mm BB7 front brake
- Tires : Der Kaiser, speed king 2.1
- Maxxis ultralight tubes
- Cranks/freewheel : Crewkerz, splined.
- Try-All single cages pedals
- Titanium, alloy, nylon (hs33 crossover "clips") bolts almost everywhere
- Crewkerz Stem
- Trialtech Carbon bar.
Approx. Weight : 9.4kg, which is not so bad i think using a bb7 and a der Kaiser
post-8639-0-22255600-1373630626_thumb.jp
post-8639-0-24339800-1373633485_thumb.jp
post-8639-0-81269900-1373634030_thumb.jp
post-8639-0-09790500-1373634047_thumb.jp
post-8639-0-07008400-1373634070_thumb.jp
post-8639-0-60727500-1373634087_thumb.jp
post-8639-0-34513000-1373634119_thumb.jp
post-8639-0-58900900-1373634137_thumb.jp
  • Like 1
Looks nice. Could you put a picture up of the rear brake mounts though please.
I don't have one, if i clearly understand what you want, but i'll try to take one ;-)
gorgeous, but not alot of tyre clearance! :nerd:
Considering the der Kaiser as a "big" Tire, there is plenty.
Your impression is probably coming from the fact that pictures don't do justice to that point.
There are 1 to 2 centimeters of clearance everywhere, i think you can call that plenty. :wink2:
I know it seems like a strange request and if you don't have one then it doesn't matter. I was just wondering about the welds just below the mounts.
I just checked the tarty website and they had some pics up on there. The mounts look solid but surely there's a weak point there around the weld?
Edited by dngr2self
